2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-11-03T17:25:29+00:00
    Yes, I can go to ebay.com without it crashing....but I did so before the update as well. I even bought something last yesterday :-).
    I applied the update last night and believe that the incident rate is down. I had no crashes during ~3 hours of work. I also sense that my Surface Pro 4 is running smoother.
    Nevertheless, I did experience the crash once (so far) this morning. It is not obvious that this happens consistently on any particular website. I returned to the same site without a problem and refreshed multiple times without incident.
    Microsoft (or perhaps Intel) still have work to do.
    -bs
    2015-11-03T19:31:33+00:00
    The Nov firmware update fixed the flashing screen in Edge, but the crashes still occur.  Granted not as frequently, but still issue with Edge and the Intel drivers.   Everywhere else is fine.
    As others have mentioned, the connected standby issue is still here.  Closed lid on SP4 last night, woke up this morning to a very, very hot device as it was plugged in to charge.  Had no apps open when I shut the lid.   Will be setting this to hibernate until this issue is resolve.
    Outside of this, the device is great and I am glad I purchased it.  They just need to work these last few issues out.
