2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-11-03T02:11:52+00:00
    So far so good, no crashes or weird noises from the speakers. The device is perfect!
    2015-11-03T16:23:08+00:00
    After the update it worked well for a day and then the display driver crash started to occur again. Can anyone go to www.ebay.com without getting the display driver crashing????
