2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-11-02T22:03:49+00:00
    Same here. Read great reviews online before product launch, but how is it possible none of the early reviewers did not experience the same problems as a lot of owners did??? I mean every time I go online to browse websites, my surface pro 4 either does not load pages correctly even just using IE or has display driver crashes. Try going to www.ebay.com , scroll up and down couple of times, and see if get a driver display crash. Also try to do satellite view from google maps of any address (not from the app) and see if you can even do it or does the page not load. Battery life has been a lot better when I don't use Edge. Why so many problems??? Microsoft are you listening to US at all?
    2015-11-02T22:53:32+00:00
    That's the same error phrasing I've gotten a couple of times a day while using Firefox (and all Windows updates had been installed). In discussions with the Surface Answer Desk, they moved pretty quickly to suggesting I exchange the device, which I'll be doing this week. Will report back if the problem continues on the new one.
