2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-11-02T19:31:19+00:00
    I've noticed that Microsoft Edge has trouble loading certain websites.
    For example going to the bodybuilding.com forums will cause huge lag and the driver crash (even BSOD)
    Chrome runs fine on the same page, so it is indeed a problem with Edge / the driver. Very disappointing.
    2015-11-02T20:11:53+00:00
    Confirmed here too on a SP4 8GB 256GB. Constant display driver crashing (in some cases ever 10 mins), poor sleep (10% battery depletion per hour).  Very frustrating and hoping it gets resolved soon - the lack of acknowledgement and communication this is pretty poor.
