2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-11-02T01:16:16+00:00
    I decided to pick up SP4 core m coming from a MacBook Pro. Had it for a couple of days and kept on getting Display Driver Crashes. Very disaapointed to see that many people are experiencing the same issue on such a "premium" product from Microsoft. At first I thought it was Edge so I switched to IE. Same issue. No wonder people line up outside Apple stores when they launch products while Microsoft stores never have lines. Very disappointed with Microsoft. When I called Microsoft and spoke to the tech support, they tell me it is a known issue but there is no fix. So Microsoft expects me to dish out my hard earned money for a defective product? Is this how Microsoft takes care of their customers? I'll give it 30 days before I return it and go back to Apple. Products should work out the box and shouldn't require me to search for fixes online! Am I being unreasonable? Loosing my patience.
    2015-11-02T02:53:23+00:00
    Having the same issue, all updates are applied. Is there any updates for an updated driver forthcoming?
