2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-11-08T18:41:02+00:00
    Did you reinstall the firmware update of Nov 2nd?  Also, where did you see the crash, what were you in and doing?
    My crashes are almost non-existent now.  Haven't seen one in a few days.
    Also, do realize this is not a Surface Pro / Book issue, it is an Intel driver issue on the new Skylake processors.  Others are reporting the same problem on Lenovo and other OEM's hardware.  Intel needs to get this resolved soon.
    2015-11-08T15:47:44+00:00
    Put my surface 4 back in the Fast Ring last nite and installed th2/10586. First thing this morning the display error message came back. Patience is a virtue???
    GRV
