2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-11-08T22:48:18+00:00
    While in Edge, see if the video you are trying to play is flash based or not.  I think that is part of the issue too.   If so, try to turn off flash and see how things go.
    2015-11-08T22:29:10+00:00
    Strange,,, I did an update check about 2300 last nite after installing th2 and there weren't any. Just did another check and there were the 11/2 update and an insider hub update. I'll try Edge again and see if it's fixed.
    Seems like Edge has the most frequent problems.
    I've only had one blue screen so far and the help desk was no help,, it's only a nag and seems like Intel and MS should be a little quicker on the fix,, seems like all the publicity about year long collaboration should result in stability.<G>
    GRV
