2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-11-26T21:32:21+00:00
    My update lasted about a days worth. Bummer!
    2015-11-26T20:25:36+00:00
    The latest update from 11/24 might have fixed the display driver for me. So far I haven't had any crashes since, bur I've been here before.... will update if the crashes return.
    They're Back....
