2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-11-27T17:11:21+00:00
    Yes, I think at this point FIX THIS NOW! is the only way to go. And by now I mean yesterday...
    2015-11-27T16:51:54+00:00
    Alright, it's been more than a month since this problem surfaced (ha), with some 22 pages of replies in this forum.
    Still no fix, with the damned driver randomly failing in the middle of doing things, not to mention the screen staying black/blank after waking from sleep, even after disabling Windows Hello, which was deemed to be one of the offenders (thereby removing the lone, flimsy unique selling proposition of this device and OS in the first place).
    Now I'm not one for expletives or all caps, but seriously: WHAT THE *%#( ARE YOU FOOLS DOING?  It's 2015, you've got a tiny core of loyal fans who pay gobs of money for a product, and we're STILL grappling with freakin' DISPLAY DRIVER CRASHES?!?!!  Are you joking us?!!!?
    FIX THIS.  NOW.
