2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-11-27T18:46:09+00:00
    I am experiencing the same problem with the screen flickering on low brightness as well.
    i7 540 Iris graphics latest updates installed.
    2015-11-27T18:10:14+00:00
    Just purchased a Dock and plugged in my Dell 3007 monitor - simple right?  Nope - no signal from the Dock to the monitor. Tried a Dell 2007 also - same thing. Cables, etc, are fine when hooked directly to the SP4 mini display port. Spent $1800 on this by now, and have nothing useful.  I'm hopeful they will get it "sort of " working eventually, but this is inexcusable.
