2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-11-27T20:42:49+00:00
    My SP4 Core M3 has been running nearly issue free since using the recovery image to reimage the drive and using Chrome (suggest going into 'chrome://flags' in the address bar and setting 'Enable touch events' from 'Automatic' to 'Enabled' to prevent Chrome from disabling touch input and setting 'Disable touch adjustment' to 'Enable' seems to have eliminated ghost touches).  Only issue, knock on wood, is closing Fingerprint Touch Cover 4 keyboard to put it to sleep then reawaken with power button will often cause a graphics driver crash/recovery.  Fortunately, using the power button only to sleep and wake seems to work reliably so as a temporary work-around until Intel/MS fixes the software issue I've set Power Options>Power buttons and lid>Lid close action to 'Do nothing' for both on battery and plugged in.
    2015-11-27T20:30:07+00:00
    Ben_mK: I don't think this is fixed with the 23 Oct update. I have that one as well as 2 Nov and 18 Nov updates but I still see the driver crashing.
