2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-11-28T01:21:59+00:00
    I have resorted to social media (twitter and facebook). Potential new buyers have to know about this before they become victims of this ****. We have been screwed by Microsoft with a crappy product and no fix. Do what you can and let people know about this before they buy. It's better than just getting screwed by Microsoft.
    2015-11-27T20:52:28+00:00
    grvak,
    Thanks for your query. Please check your Windows update history and make sure that you have the latest update. While checking look for:  “Surface Hardware Update – 10/23/2015”.
    If you do not see it, please run updates manuallyand once done, manually restart your Surface and let us know the outcome.
    I have all of the updates done.   But as soon as my SP4 is asked to play a video in HD the display drivers crash.  Some times it recovers.  Some times it takes out the entire OS and requires a hard power down / reboot.
    Also this thing runs really hot.
    I have the i7, 16gig ram, 500 gig SSD version.   For the money I spent, I expect way better!  And I sure as **** do not expect that I am going to have to do IT work on it right out of the box to get it to function.
    Tony
