2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-11-28T06:50:09+00:00
    I agree with diskw0rm 100%.  These are the fundamentals which Microsoft can't even get right.  Light bleed is horrible on all generations of Surface.  And there are so many bad drivers its ridiculous.  I really want to love the Surface but Microsoft apparently laid off all of its quality assurance guys with the Lumia guys.  It's sad really.
    2015-11-28T06:48:14+00:00
    The first SP4 unit they sent was suffering from excessive backlight bleeding and the graphics driver kept crashing. I asked for an exchange and explicitly asked them to check the replacement device before they ship it. Guess what? The replacement device is suffering from backlight bleed, exactly in the same area. The graphics driver still crashes also. If I hadn't opted in for the Advanced Exchange program, I would have assumed they had returned the same unit!
    I think there are wider quality problems with manufacturing and I am not sure how long it takes for them to solve it. So as much as I like the device, I am returning it and asking for a refund :(
