2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
  1. Barb Bowman 80,810 Reputation points MVP Volunteer Moderator
    2015-11-28T11:32:00+00:00
    Who at Microsoft told you that a two button reset is dangerous and should not be used more than once?
    If you have a Surface Pro or Pro2/3/4 or Surface Book, this two button reset process is used to fix a variety of issues. https://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/surface-wont-turn-on-or-wake-from-sleep?os=windows-10 for example.
    No amount of two button resets will fix the display adapter has stopped working issue. This Intel Display driver issue is present on non Surface computers as well. It's a driver issue that someone decided wasn't serious enough to stop shipping new Surface hardware. Microsoft probably thought that Intel would have a fixed driver by the time the devices launched, etc. I'm sure they knew how the driver performed.
    2015-11-28T07:17:37+00:00
    I have 2 SP4 and I'm returning one this week. I just received my new SP4 yesterday and it suffers from the same issues as the others. So I'll give them 20 days to fix this issue. If these are not fixed, I'm reluctant to say, I'll go with another company. I have the SP2 which works perfectly. My partners SP3 works perfectly. I want my SP4 to work perfectly to merit the large amount of money I spent on it. Otherwise, I'll go another route. It's not like MS makes the ONLY laptop tablet convertible!
    20 Days MS! Or you'll lose a client for good!
    My damn SP4 spent 3 hours reformatting yesterday... 3 hours... And I did this on BOTH SP4 to start new from the image you have. The update to TH2 took AT LEAST an hour! GOD!
    But on a lighter note, while the device is on, it works well. :)
