2015-10-29T15:57:46+00:00
Split from this thread.
2016-02-17T23:02:27+00:00
Hi All,
Josh
2016-02-15T00:03:05+00:00
Hi
Hope this helps
K
2016-01-15T11:25:17+00:00
Try a two button reset
655 additional answers
    2015-11-28T14:41:36+00:00
    I have had a replacement surface pro 4 (it took 8 working days to arrive!) which appears to be much more stable than my first surface pro 4.
    I am no longer having to routinely do the volume and power button restart, however I am still having display driver crashed and flickering displays.
    I was over the moon that Microsoft had released a surface pro 4 as the guys I work with love their surface pro 3s. I had been saving up for almost a year to purchase a MacBook pro to replace my aging HP laptop. I do not usually shell out this much on Laptops but wanted something reliable, lightweight and future proof. My colleagues strongly suggested that I purchase a surface pro 4 instead of a MacBook, a decision I am still yet to be fully happy about.
    I cannot in all honesty recommend that any one purchase a surface pro 4 over a MacBook. I have friends who have MacBook airs for 4-5 years now with absolutely no issues. At this moment in time I do not believe in quality of this product. If it last more that a year without dying on me I will be surprised.
    2015-11-28T12:34:32+00:00
    While I'm an unhappy camper with my SP4, I agree with Barb above. The display driver is annoyance that WILL be fixed pretty soon. But MS should really come out and say something to let us know what is going on. These are very expensive devices and if the many problems are addressed by only silence (and "Reset your device for the umpteenth time") - those of us who bought SP4's and SB's as an alternative to MacBooks are going to run back the other way and never return. I know a couple who already have.
