Airpods Not connecting property to Surface Pro 10
2019-08-30T19:42:05+00:00
I can pair my airpods with my Surface book 2 laptop, however they will rapidly connect and disconnect. And when it says "connected", no sound will play through the airpods. I've tried looking up a couple of fixes online but nothing is working.
Surface | Surface Book | Sound and camera
2019-11-13T20:44:42+00:00
I had the same exact problem with the Airpods Pro. My problem, as you mentioned, was the the rapid flickering back and forth between Paired andConnectedwith the Airpods ultimately never connecting.
For me, the solution was to restart the whole process as follows:
  1. Place your Airpods or Airpods Pro back into the case > Close the case > Set the Airpods down.
  2. On your Surface computer > Settings > Devices
  3. Select Add Bluetooth or other device > Bluetooth
  4. Pickup Airpods Case > Open Airpods case (Don't remove Airpods) > Press/Hold button on back of Airpods case until the Airpods are located by your Surface computer.
Your Surface computer should be able to at least find your Airpods by following the above steps.
*This is where I started having the problem stated at the beginning*
Solution:
  1. Go to settings > Type "Device Manager" in the search box.
  2. Once Device Manager is open, select Human Interface Devices
  3. Locate Bluetooth Low Energy GATT complaint HID device > Right-Click >Properties
  4. Select the 5th tab called Power Management
  5. Locate the checkbox "Allow the computer to turn off this device to save power" and UNCHECK this box!
  6. RESTART COMPUTER! *(This is what ultimately fixed my problem)*
Hope this helps! Wish it wasn't this complicated but oh well ¯\_(ツ)_/¯
2019-12-11T22:53:18+00:00
I couldn't even find a "Bluetooth Low Energy GATT complaint HID device"  under Human Interface Devices, and any other Bluetooth options in the Device Manager didn't have a power management option. However, when I clicked on "Converted Portable Device Control device properties" under Human Interface Devices, I found the power management option and disabled it. My AirPods are working correctly now. I hope I'm not saying this too soon and that it's not just because I just updated my Surface, but I've had this problem for a long time and updates haven't fixed the problem before. Hopefully this will work for you. It's unfortunate we have to deep dive into our settings to get headphones to connect right.
184 additional answers
    2021-01-22T15:40:36+00:00
    Hi everyone,
    I have exactly the same problem with my Surface pro 6.
    I used to be able to connect my Airpds but now they are paired but never connected not even one second!
    I have changed my airpods and they are brand new but still the same problem. I was wondering if Microsoft could help me with that because I can use my airpods with all other devices except my surface!
    thank you  in advance for your help
    SH
    2021-01-20T18:31:21+00:00
    This worked for me but as soon as I went back to my surface it had resumed its previous behaviour.
    I am astonished that this issue hasnt be resolved .
    2021-01-19T19:36:13+00:00
    When you turn on the Surface Pro, hold down the power button and volume button. A different screen should pop up and click the bluetooth button to turn it off. Then, exit and press restart. When the normal Surface Pro screen pops up, click in settings to check your bluetooth so you know it is off. Shut down your Surface Pro again and hold down the power button and volume button to turn it on again. Finally, turn on your bluetooth button and restart. The Surface Pro should connect to the airpods at that point so just make sure it isn't connected to any other devices. I hope this helps. Goodluck!
