Airpods Not connecting property to Surface Pro 10
2019-08-30T19:42:05+00:00
I can pair my airpods with my Surface book 2 laptop, however they will rapidly connect and disconnect. And when it says "connected", no sound will play through the airpods. I've tried looking up a couple of fixes online but nothing is working.
Surface | Surface Book | Sound and camera
2019-11-13T20:44:42+00:00
I had the same exact problem with the Airpods Pro. My problem, as you mentioned, was the the rapid flickering back and forth between Paired andConnectedwith the Airpods ultimately never connecting.
For me, the solution was to restart the whole process as follows:
  1. Place your Airpods or Airpods Pro back into the case > Close the case > Set the Airpods down.
  2. On your Surface computer > Settings > Devices
  3. Select Add Bluetooth or other device > Bluetooth
  4. Pickup Airpods Case > Open Airpods case (Don't remove Airpods) > Press/Hold button on back of Airpods case until the Airpods are located by your Surface computer.
Your Surface computer should be able to at least find your Airpods by following the above steps.
*This is where I started having the problem stated at the beginning*
Solution:
  1. Go to settings > Type "Device Manager" in the search box.
  2. Once Device Manager is open, select Human Interface Devices
  3. Locate Bluetooth Low Energy GATT complaint HID device > Right-Click >Properties
  4. Select the 5th tab called Power Management
  5. Locate the checkbox "Allow the computer to turn off this device to save power" and UNCHECK this box!
  6. RESTART COMPUTER! *(This is what ultimately fixed my problem)*
Hope this helps! Wish it wasn't this complicated but oh well ¯\_(ツ)_/¯
2019-12-11T22:53:18+00:00
I couldn't even find a "Bluetooth Low Energy GATT complaint HID device"  under Human Interface Devices, and any other Bluetooth options in the Device Manager didn't have a power management option. However, when I clicked on "Converted Portable Device Control device properties" under Human Interface Devices, I found the power management option and disabled it. My AirPods are working correctly now. I hope I'm not saying this too soon and that it's not just because I just updated my Surface, but I've had this problem for a long time and updates haven't fixed the problem before. Hopefully this will work for you. It's unfortunate we have to deep dive into our settings to get headphones to connect right.
184 additional answers
    2020-11-02T23:43:57+00:00
    StudentInEng I don't get it. Are you saying that removing the driver altogether still leaves the laptop in a working condition? And the Surface will still support Bluetooth? after all the Pen is using Bluetooth and I'm not sure that the keyboard isn't. Can you please confirm clearly that uninstalling the driver the way you suggest, is not leaving the laptop in an unusable condition?
    2020-11-02T22:19:13+00:00
    my airpods started acting up and disconnecting again and this worked for me TYSM
    2020-11-01T22:25:29+00:00
    Hi there,
    I recently got help from an IT support center (GeekSquad) for this issue. I tried the "power management" solution but it did not work for me. The IT guy took over my computer and fixed it for me. He actually uninstalled the Bluetooth card (you can find it in “device manager”) and restarted my computer. Check it out:
    This is the only thing that worked for me. When you uninstall the bluetooth card, you need to restart your computer. After doing this, the bluetooth card will re-install itself and there shouldn't be any damage to your other bluetooth connections. My surface pen still works fine. Uninstalling the bluetooth card essentially acts as a "reset" for the bluetooth system on your computer.
    I had tried re-installing my airpods pro a million times and it would work once in a blue moon. Microsoft needs better technical support for this. $400 airpods and a $2000 surfacebook 2 should be able to connect with no difficulty. If I had not reached out to GeekSquad, I would still be extremely disappointed and frustrated. Hopefully this works for you guys, and I'm sorry if is doesn't. Take care.
