Airpods Not connecting property to Surface Pro 10
2019-08-30T19:42:05+00:00
I can pair my airpods with my Surface book 2 laptop, however they will rapidly connect and disconnect. And when it says "connected", no sound will play through the airpods. I've tried looking up a couple of fixes online but nothing is working.
Surface | Surface Book | Sound and camera
2019-11-13T20:44:42+00:00
I had the same exact problem with the Airpods Pro. My problem, as you mentioned, was the the rapid flickering back and forth between Paired andConnectedwith the Airpods ultimately never connecting.
For me, the solution was to restart the whole process as follows:
  1. Place your Airpods or Airpods Pro back into the case > Close the case > Set the Airpods down.
  2. On your Surface computer > Settings > Devices
  3. Select Add Bluetooth or other device > Bluetooth
  4. Pickup Airpods Case > Open Airpods case (Don't remove Airpods) > Press/Hold button on back of Airpods case until the Airpods are located by your Surface computer.
Your Surface computer should be able to at least find your Airpods by following the above steps.
*This is where I started having the problem stated at the beginning*
Solution:
  1. Go to settings > Type "Device Manager" in the search box.
  2. Once Device Manager is open, select Human Interface Devices
  3. Locate Bluetooth Low Energy GATT complaint HID device > Right-Click >Properties
  4. Select the 5th tab called Power Management
  5. Locate the checkbox "Allow the computer to turn off this device to save power" and UNCHECK this box!
  6. RESTART COMPUTER! *(This is what ultimately fixed my problem)*
Hope this helps! Wish it wasn't this complicated but oh well ¯\_(ツ)_/¯
2019-12-11T22:53:18+00:00
I couldn't even find a "Bluetooth Low Energy GATT complaint HID device"  under Human Interface Devices, and any other Bluetooth options in the Device Manager didn't have a power management option. However, when I clicked on "Converted Portable Device Control device properties" under Human Interface Devices, I found the power management option and disabled it. My AirPods are working correctly now. I hope I'm not saying this too soon and that it's not just because I just updated my Surface, but I've had this problem for a long time and updates haven't fixed the problem before. Hopefully this will work for you. It's unfortunate we have to deep dive into our settings to get headphones to connect right.
184 additional answers
    2020-10-13T04:30:57+00:00
    Hi, no - I tried for weeks and then spent over an hour on the phone with customer support... unfortunately the consultant didn't seem well trained and didn't know his stuff at all....he ended up saying he couldn't fix it and hung up on me :  (  Since then, I've had a long break from even trying as I also have an issue with usb not working and I've lost work and it all became too frustrating - so I took a break! Just about to try and tackle it again. Will let you know if I have any success!
    2020-09-26T21:11:57+00:00
    Alas i was hoping to avoid this but i guess i need to get rid of the driver ans reinstall. can you please ask your son where did he find the driver and maybe if he still has the name of the file.
    my laptop is the full scale metal laptop and not the one with the black/gray detachable keybord. thanks much.
    2020-09-25T22:07:38+00:00
    after trying EVERYTHING under the sun to connect to my surface pro 6... my son deleted the blue tooth and reinstalled it and that is when blue tooth recognized that i had a new device (my airpods) and  they showed in my sounds drop-down menu!!!  they finally connected and no dropping .... no checking or unchecking anything...  no disconnecting my other devices like my phone or windows pc in order to use them on my surface!
