Airpods Not connecting property to Surface Pro 10
2019-08-30T19:42:05+00:00
I can pair my airpods with my Surface book 2 laptop, however they will rapidly connect and disconnect. And when it says "connected", no sound will play through the airpods. I've tried looking up a couple of fixes online but nothing is working.
Surface | Surface Book | Sound and camera
2019-11-13T20:44:42+00:00
I had the same exact problem with the Airpods Pro. My problem, as you mentioned, was the the rapid flickering back and forth between Paired andConnectedwith the Airpods ultimately never connecting.
For me, the solution was to restart the whole process as follows:
  1. Place your Airpods or Airpods Pro back into the case > Close the case > Set the Airpods down.
  2. On your Surface computer > Settings > Devices
  3. Select Add Bluetooth or other device > Bluetooth
  4. Pickup Airpods Case > Open Airpods case (Don't remove Airpods) > Press/Hold button on back of Airpods case until the Airpods are located by your Surface computer.
Your Surface computer should be able to at least find your Airpods by following the above steps.
*This is where I started having the problem stated at the beginning*
Solution:
  1. Go to settings > Type "Device Manager" in the search box.
  2. Once Device Manager is open, select Human Interface Devices
  3. Locate Bluetooth Low Energy GATT complaint HID device > Right-Click >Properties
  4. Select the 5th tab called Power Management
  5. Locate the checkbox "Allow the computer to turn off this device to save power" and UNCHECK this box!
  6. RESTART COMPUTER! *(This is what ultimately fixed my problem)*
Hope this helps! Wish it wasn't this complicated but oh well ¯\_(ツ)_/¯
2019-12-11T22:53:18+00:00
I couldn't even find a "Bluetooth Low Energy GATT complaint HID device"  under Human Interface Devices, and any other Bluetooth options in the Device Manager didn't have a power management option. However, when I clicked on "Converted Portable Device Control device properties" under Human Interface Devices, I found the power management option and disabled it. My AirPods are working correctly now. I hope I'm not saying this too soon and that it's not just because I just updated my Surface, but I've had this problem for a long time and updates haven't fixed the problem before. Hopefully this will work for you. It's unfortunate we have to deep dive into our settings to get headphones to connect right.
184 additional answers
    2020-05-02T19:43:27+00:00
    I was haveing the same issue and then I found out when yoo have your iphone bluetooth on with e the earbuds connected (within the vicinity) it interferes with the computer bluethhoth. Once I switched the bluetooth of on the iphone it worked like a charm
    2020-04-27T04:27:05+00:00
    I love how using Microsoft products makes small problems turn into long-winded troubleshooting sessions. Let's take a step back here and look at the bigger picture - all we're asking for is to simply get a wireless headphone to pair with Windows. The fact that people on this forum are getting genuinely exited when they're able to pair headphones is absolutely hilarious. What decade are we in Microsoft?
    so disgraceful ive been trying to connect my airpods to my computer for a meeting for two hours... it never ended up working as usual
    2020-04-23T02:36:18+00:00
    The power management is with Device Manager / Human Interface Devices / Bluetooth HID Device. Double click Bluetooth HID Device, then go to Power Management tab to disable Allow the computer to turn off this device to save power. You may have multiple Bluetooth HID Device, do the same to all to try. I have the same issue on airpods pro and surface pro 6, sometimes restart the surface pro 6 fixes the issue.
