ok so i figured out the problem. when i got to controll panal and go to program. and click turn window feature on and off. and when i check hyper v (which allows me to have multiple power option like balance, high power, and high performance) and when they install the program then i get this problem with power butten. and no im not pressing down the power butten i just click it. i think they need an update about that because i do need high performance for my surface pro 3 bucause on balance mode you cant use full potential. the cpu performance is limited and wifi succs beacuse they limit them. i know that microsoft promissis the 9 hours of batery life but its not rigt that they are limiting the potential of the divice it self for the sake of the batery power usage..... i unchecked the hyper v and the power butten works fine. but im stuck with low performance.... you guys need to update the software
Surface Pro 3 Power/Lock button not working properly after Windows Update
So I have the Surface Pro 3, which I love, however after the most recent Windows update when I press the power button once it brings up the "Slide to shutdown" screen. I read that Microsoft fixed an issue with the power button just before the release but I didn't have an issue until after the update. So I am assuming that the recent update caused the same issue that they previously fixed.
Thoughts?
Thanks for the prompt replies! It would do it when I would click or tap the button for, what I would guess would be, 1 second. It actually quit doing it by the end of the day.
A little more information:
I installed the large updates and when they finished I almost immediately noticed the power button issue. It was late so I didn't want to look too much into the issue, so after trying to research exactly what the recent update was I powered the device off for the night. I use the Surface for work and school; while at work I noticed that it was still having an issue, which was quite annoying as I use it while assisting customers. So on my break I decided to look for a fix that I didn't find. I tried rebooting the device and shutting it down for a few minutes, but it was still acting up. I didn't have time to really look into a resolution; hence my post.
However, by the end of the day it stopped bringing up the "Slide to shut down" prompt when clicking the power button. I wish I knew why it had this problem and why it decided to start working.
Anyway, thanks again for the replies!
43 additional answers
2014-08-01T14:55:48+00:00 I tried this and it had zero effect. I still see Slide to shutdown
2014-08-02T05:21:13+00:00 I tried tense steps and they had no effect. I still get the slide to shutdown prompt when I hit the power button.
2014-08-02T10:25:51+00:00 Ive been having the same problem too. Ever since the recent update, my surface cannot be put to sleep with the power button; I have to swipe it from the right, hit settings, power, and then hit sleep. Whenever I try to put it to sleep with the power button (brief, single click), nothing happens and I get prompted to shut down the surface a few seconds later. If anyone knows a fix, I would sure appreciate a solution to this problem!
