Hello all
We wanted to let you know that an update to resolve this is still being worked on. Please continue to post your experiences and technical details.
Mod Edit: Samsung SSD Optimization Utility for Surface Pro 3 now available.
Best regards
I've just had to update the firmware in another device that had a Samsung 840EVO SSD because they had a serious firmware bug with it. Out of curiosity I tested the Samsung drive in my Surface Pro 3 and it looks like it has exactly the same issue (the SP3 drive is closely related to the 840 series I believe, but an OEM version.
The test is simple, just look at the read rate across the drive. Older data (OS, installed apps) suffered from terrible read performance after a month or so. Newly written data is fine.
As you can see, much of the drive is down to 50MB/s now. It should be a fairly level line right the way across at about 350+MB/s. This test was run with AC power connected and nothing else running.
If this is the same issue as the 840EVO, the good news is it can be corrected with a firmware update and refresh of the data. Bad news would of course be Microsoft need to look into it first, then get the Samsung engineers looking into it.
Perhaps some other people could run the test too, and post results. Remember the drive needs to be a month or more old, so that the data can have been sitting there only being read during that time.
Further details of the bug and the fix that Samsung released can be found here:
Hello all
Best regards
I would like to sound my voice for this issue, too. I just started the Samsung tool to see what happens, and of course the mSATA doesn't get recognized. I have the SP3 128 since day one and though the performance seems rather ok at the moment (~280 mb/s average in HD Tune), there are clearly some small areas where the average is much much higher and the line is rather flat instead all over the place. I know this is Samsungs **** up, but hell, I guess it wouldn't be bad if Microsoft worked with Samsung on this.
20 days later and I thought I'd check to see how the drive is doing, trending downwards it seems.
Use something like ATTO to Benchmark SSDs.
http://www.majorgeeks.com/mg/getmirror/atto_disk_benchmark,1.html
__DO NOT__ use Atto for testing for this issue.
Rick, Please follow the links in the original post for more details of this potential problem (was a real problem on the other Samsung drive and they have provided a fix for it) and explanations of why it didn't show up before and why a test like ATTO would give completely false results.
In short, it is data that is old and unchanging (like the OS files) that slows down after months. A test like ATTO writes fresh data and then measures the speed to read it back, and freshly written data does not have any problems.
You need to use a test that reads only, from all across the drive covering old data and files as well as more recently written ones.
