Surface Pro 6 i7 1TB Battery Drain from 100% to 74% when turned off
2019-08-17T18:12:04+00:00
I seem to be plagued by a battery drain issue with the Surface Pro 6.
Here is a quick rundown:
7/6/19 I bought a Surface Pro 6 i7 1TB. This device turned out to have a defective screen so I took it in for a replacement on 7/27.
7/27/19 I am assigned (what I later discovered was a refurbished unit) a replacement unit. A few days after that I started to notice that when I leave it at 100% at night, unplug it, go to bed, and when I wake up in the morning it would only have 74% o 75% battery left! Also when it is 100% and I unplug it, take it with me to work, by the time I reach my office about 45 minutes later then turn it on it only has 74 to 75% battery left! I was able to observe this multiple times. I tried several troubleshooting steps to no success. I am not using hello cortana face unlock or anything fancy.
8/15/19 I went to a Microsoft Store to ask them to take a look at the battery drain issue, and they said they saw nothing wrong and suggested I factory reset the unit which I did when I got home! But the following day the same issue appeared!
8/16/19 I went back to the Microsoft Store and told them the issue has not gone away. They issued me a brand new Surface replacement. At last I thought that was the end of the issue. I left the unit charging overnight, and this morning it was showing 100%. Out of curiosity I wanted to find out if this unit would have the same issue so I turned off the device at 100%, unplugged it, then left it for a couple of hours. When I turned it back on the battery was showing 74%!!
At this point I don't even know what to do. If anyone has a solution to this problem please share, otherwise I have no choice but to make another trip to the Microsoft Store for a possible fourth replacement.
Here is the drop observed this morning -
08:11:51 Suspended 100 % 47,150 mWh
10:13:56 Connected standby AC 74 % 34,960 mWh
My entire battery report is below:
2019-08-1614:45:56 Active Battery 47 % 22,420 mWh
14:49:23 Connected standby Battery 46 % 21,840 mWh
14:49:23 Suspended 46 % 21,840 mWh
16:22:26 Connected standby Battery 46 % 21,790 mWh
16:22:26 Active Battery 46 % 21,790 mWh
16:22:26 Active AC 46 % 21,790 mWh
16:31:39 Active Battery 50 % 23,960 mWh
16:31:51 Connected standby Battery 50 % 23,910 mWh
16:32:52 Connected standby AC 50 % 23,870 mWh
16:33:09 Active AC 50 % 23,950 mWh
17:11:21 Active Battery 70 % 33,260 mWh
17:12:11 Active AC 69 % 33,080 mWh
19:42:15 Active Battery 100 % 47,690 mWh
19:42:21 Connected standby Battery 103 % 49,200 mWh
19:43:04 Connected standby AC 103 % 49,200 mWh
19:43:18 Suspended 103 % 49,200 mWh
19:47:02 Active AC 100 % 49,200 mWh
20:22:00 Suspended 100 % 49,200 mWh
20:26:51 Active AC 100 % 49,200 mWh
2019-08-1707:52:00 Suspended 96 % 47,150 mWh
07:57:23 Active AC 100 % 47,150 mWh
07:57:23 Suspended 100 % 47,150 mWh
07:58:28 Active AC 100 % 47,150 mWh
08:04:00 Suspended 100 % 47,150 mWh
08:07:48 Active AC 100 % 47,150 mWh
08:11:51 Connected standby AC 100 % 47,150 mWh
10:13:56 Connected standby Battery 74 % 34,960 mWh
10:13:56 Active Battery 74 % 34,960 mWh
10:13:56 Active AC 74 % 34,960 mWh
10:14:18 Active AC 74 % 34,850 mWh
10:16:26 Report generated AC 75 % 35,130 mWh
    2019-09-05T13:24:27+00:00
    Hi, just wanted to update here that I have now received a second replacement from Microsoft for my Surface Pro 6 which showed the battery drain problem. I sent my original device and got a replacement. The replacement too had the same problem, so I got another replacement.
    Question to all those facing this problem - Have you updated your devices with the Feature update to Windows 10, version 1903? Is it possible that the problem won't occur if I do not update this feature update and wait for it to become unavoidable? If yes, I am wondering if I should stay away from it until Microsoft addresses the problem.
    2019-09-05T13:39:18+00:00
    I experienced the issue both before and after updating to version 1903. I had hoped that 1903 would solve it.
    2019-09-05T13:52:06+00:00
    I noticed it before 1903, and have it sporadically after turning off the connected standby mode.
    2019-09-05T14:05:44+00:00
    I really don't think that connected standby is the issue because it happens when the device is fully shut down! For me at least, power loss is negligible when in sleep/standby mode, but it drops to around 75% after starting up from a full shut down.
    2019-09-05T21:49:25+00:00
    As far as I can tell, in my case at least, the 25% power drop only occurs after shutdown, not sleep.
    Hibernation is effectively the same as shutting down. The only difference is that the contents of the RAM, which are usually lost during shutdown as RAM is temporary memory, is instead stored on the SSD permanent storage, so that on start up it can be retrieved so that you pick up exactly where you left off.
