Surface Pro 6 i7 1TB Battery Drain from 100% to 74% when turned off
2019-08-17T18:12:04+00:00
I seem to be plagued by a battery drain issue with the Surface Pro 6.
Here is a quick rundown:
7/6/19 I bought a Surface Pro 6 i7 1TB. This device turned out to have a defective screen so I took it in for a replacement on 7/27.
7/27/19 I am assigned (what I later discovered was a refurbished unit) a replacement unit. A few days after that I started to notice that when I leave it at 100% at night, unplug it, go to bed, and when I wake up in the morning it would only have 74% o 75% battery left! Also when it is 100% and I unplug it, take it with me to work, by the time I reach my office about 45 minutes later then turn it on it only has 74 to 75% battery left! I was able to observe this multiple times. I tried several troubleshooting steps to no success. I am not using hello cortana face unlock or anything fancy.
8/15/19 I went to a Microsoft Store to ask them to take a look at the battery drain issue, and they said they saw nothing wrong and suggested I factory reset the unit which I did when I got home! But the following day the same issue appeared!
8/16/19 I went back to the Microsoft Store and told them the issue has not gone away. They issued me a brand new Surface replacement. At last I thought that was the end of the issue. I left the unit charging overnight, and this morning it was showing 100%. Out of curiosity I wanted to find out if this unit would have the same issue so I turned off the device at 100%, unplugged it, then left it for a couple of hours. When I turned it back on the battery was showing 74%!!
At this point I don't even know what to do. If anyone has a solution to this problem please share, otherwise I have no choice but to make another trip to the Microsoft Store for a possible fourth replacement.
Here is the drop observed this morning -
08:11:51 Suspended 100 % 47,150 mWh
10:13:56 Connected standby AC 74 % 34,960 mWh
My entire battery report is below:
2019-08-1614:45:56 Active Battery 47 % 22,420 mWh
14:49:23 Connected standby Battery 46 % 21,840 mWh
14:49:23 Suspended 46 % 21,840 mWh
16:22:26 Connected standby Battery 46 % 21,790 mWh
16:22:26 Active Battery 46 % 21,790 mWh
16:22:26 Active AC 46 % 21,790 mWh
16:31:39 Active Battery 50 % 23,960 mWh
16:31:51 Connected standby Battery 50 % 23,910 mWh
16:32:52 Connected standby AC 50 % 23,870 mWh
16:33:09 Active AC 50 % 23,950 mWh
17:11:21 Active Battery 70 % 33,260 mWh
17:12:11 Active AC 69 % 33,080 mWh
19:42:15 Active Battery 100 % 47,690 mWh
19:42:21 Connected standby Battery 103 % 49,200 mWh
19:43:04 Connected standby AC 103 % 49,200 mWh
19:43:18 Suspended 103 % 49,200 mWh
19:47:02 Active AC 100 % 49,200 mWh
20:22:00 Suspended 100 % 49,200 mWh
20:26:51 Active AC 100 % 49,200 mWh
2019-08-1707:52:00 Suspended 96 % 47,150 mWh
07:57:23 Active AC 100 % 47,150 mWh
07:57:23 Suspended 100 % 47,150 mWh
07:58:28 Active AC 100 % 47,150 mWh
08:04:00 Suspended 100 % 47,150 mWh
08:07:48 Active AC 100 % 47,150 mWh
08:11:51 Connected standby AC 100 % 47,150 mWh
10:13:56 Connected standby Battery 74 % 34,960 mWh
10:13:56 Active Battery 74 % 34,960 mWh
10:13:56 Active AC 74 % 34,960 mWh
10:14:18 Active AC 74 % 34,850 mWh
10:16:26 Report generated AC 75 % 35,130 mWh
    2019-08-22T05:19:09+00:00
    Replacing a new machine can't solve this issue, because it isn't a hardware failure or a design flaw. It's caused by Windows 10 or Surface Firmware's recent update. As long as you connect your surface to internet and Windows installs the update, any new machine will have this issue immediately.  My guess is, the battery is still 100% physically, but software reading is incorrectly showing 75%.
    So yes, replacing a machine is wasting time for both customers and Microsoft. I can't see find information on whether Microsoft knows about this issue and when can it be resolved by a fixed Windows Update.
    2019-08-22T05:40:02+00:00
    This is most likely an issue with the most recent update. The sheer number of posts per day relating to battery drainage issues is no coincidence. The old saying goes "software can't damage hardware". I would hold tight and see if MS pushes something out soon (hopefully)
    2019-08-22T06:31:18+00:00
    Once we purchase Microsoft Surface, we are doomed with this kind of issues. We spend more times in troubleshooting than actual using the device. All the solutions given is waste of time only. Change device is a just the last of hope to delay the inevitable of devices faulty.
  4. Barb Bowman 80,815 Reputation points MVP Volunteer Moderator
    2019-08-22T10:01:18+00:00
    Can you please post a link to your Feedback Hub problem report?
    2019-08-23T05:32:28+00:00
    This is really becoming a depressing issue.
    It is happening on a daily basis and at this point it is actually easy for me to replicate it - turn off the laptop at 100%, unplug it, step away for 20 minutes, then return and turn it on to only 74 to 75% battery life.
    I've been chatting with Microsoft Help on Twitter DM and they just gave me standard canned run of the mill troubleshooting steps, then up and disappeared. Now they are not responding to my messages telling them none of the troubleshooting steps worked.
    I think it is safe to say at this point this is the last Surface product I am going to own.
