Surface Laptop 3 screen flickering issue - I had this with the Surface Pro 4 too
2020-04-11T01:56:49+00:00
Hello everyone,
I just noticed a problem with my two-month old Surface Laptop 3 (i7/16/256): there is screen flickering in the lower left corner of the screen. The flicker disappears when I move the mouse or play a video. I immediately panicked since I had a similar issue with my previous Surface Pro 4 and it turns out it was a hardware issue. The biggest issue is that on the Surface Pro 4 it has gotten worse over time.
Returning at this time is out of question for me, I need it for work.
Anyone else has this issue ? I'm not expecting an easy fix but who knows.
PS: Below is a video with the issue:
https://www.youtube.com/watch?v=_zE4oI9wfAk
Thanks !
Surface | Surface Laptop | Display and screen
2020-06-15T22:17:27+00:00
Ok everyone, I have great news !  (edit: not so great)
I managed to fix the issue (edit: nope).
Just as I suspected, it is indeed a power management issue where the panel tries to optimize power consumption by utilizing a technology called "panel self-refresh" which basically allows the screen electronics to refresh its current image independent of the graphics card if nothing has changed on the screen. You must disable that.
Here are the steps:
  • Open Microsoft Store, then search for and install "Intel® Graphics Command Center".
  • Open the app, go the "System" vertical tab, then go the "Power" horizontal tab
  • Disable the "Panel Self-Refresh" option on both "On Battery" and "Plugged In" modes.
The problem should instantly disappear, even before you leave the app.
EDIT: Unfortunately, the problem will only lessen in frequency, but will not disappear completely. But I will leave this post here, maybe it helps in some cases.
45 additional answers
    2020-11-05T14:06:57+00:00
    I faced the same problem with my Surface Laptop 3. I contacted the Microsoft support and am asked to install last update but it did not work. After that I am asked to reset the PC, I did reset and unfortunate, the issue has not been fixed.
    I am a student and very worried in this time of semester, such issue happened
    2020-11-05T14:49:03+00:00
    I have tried everything discussed over here but at the end I had to get it replaced.
    So if you have your  device under warranty, may be  it is better to stop waiting for Microsoft to bring out a solution and get the it replaced.
    2020-11-25T14:37:10+00:00
    The problem is with the Intel Driver, for sure.
    That said, the only thing I've done that works to solve for the flicker is to just *rollback the driver and leave it rolled back*, and forget reinstalling the Intel Driver until they fix it. The default driver is the basic one from Microsoft, which works just fine and your touchscreen capability is unaffected, so on.
    MAJOR CAVEAT: You lose the ability to control the display brightness for some reason. It forever stays at 50% brightness.
    GOOD THING: The battery still lasts for well over a workday with about 30% left if you have the device on Battery Saver, even with OneDrive updates still ongoing (I keep my device on Battery Saver, and then in OneDrive settings I disable the "Auto Pause Sync when Battery Saver is on" option).
    Not a solution, just a "jesus **** christ" option.
    2020-12-21T19:18:08+00:00
    My Surface Pro 4 starts to show a flickering thin 1/8 th 1/4 inch stripe across the bottom that sometimes shows recognizable slices of the screen content. Extremely distracting. And only happens when it overheats: such as streaming 8 hours of Christmas music yesterday or during the summer, If I use it outside for just a few minutes.
    Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz   2.50 GHz
