Surface Laptop 3 screen flickering issue - I had this with the Surface Pro 4 too
2020-04-11T01:56:49+00:00
Hello everyone,
I just noticed a problem with my two-month old Surface Laptop 3 (i7/16/256): there is screen flickering in the lower left corner of the screen. The flicker disappears when I move the mouse or play a video. I immediately panicked since I had a similar issue with my previous Surface Pro 4 and it turns out it was a hardware issue. The biggest issue is that on the Surface Pro 4 it has gotten worse over time.
Returning at this time is out of question for me, I need it for work.
Anyone else has this issue ? I'm not expecting an easy fix but who knows.
PS: Below is a video with the issue:
https://www.youtube.com/watch?v=_zE4oI9wfAk
Thanks !
Surface | Surface Laptop | Display and screen
2020-06-15T22:17:27+00:00
Ok everyone, I have great news !  (edit: not so great)
I managed to fix the issue (edit: nope).
Just as I suspected, it is indeed a power management issue where the panel tries to optimize power consumption by utilizing a technology called "panel self-refresh" which basically allows the screen electronics to refresh its current image independent of the graphics card if nothing has changed on the screen. You must disable that.
Here are the steps:
  • Open Microsoft Store, then search for and install "Intel® Graphics Command Center".
  • Open the app, go the "System" vertical tab, then go the "Power" horizontal tab
  • Disable the "Panel Self-Refresh" option on both "On Battery" and "Plugged In" modes.
The problem should instantly disappear, even before you leave the app.
EDIT: Unfortunately, the problem will only lessen in frequency, but will not disappear completely. But I will leave this post here, maybe it helps in some cases.
45 additional answers
  1. Deleted
    2021-02-28T11:20:48+00:00
    I have same issue in lower left side corner.
    2021-03-04T17:54:38+00:00
    For my Intel Graphics Command Center, Power, there isn't a Panel Self Refresh. What does that mean regarding my driver, or how to fix?
    2021-03-06T16:55:01+00:00
    I have the exact same problem, which happened around this time last year (2020), a few months after I got it. The only thing I have NOT tried is resetting the system. I think it is a driver issue as the blinking/flickering will be gone if I uninstall the Intel graphics driver and just use the basic one from Windows. But of course this has serious drawbacks so I wouldn't recommend it.
    So far the "best solution" I have found is: install the Intel Graphics Command Center and go to the Video tab. Then leave it as is and go do whatever, just do not minimize that window. The moment I switch to other tabs or minimize it, the flickering appears again. Some time ago, running the Intel Graphics Control Panel in the background also worked, until a recent major system update... It's not ideal, meaning that you'll have to repeat the process every time the machine is restarted, but it works. I just hope that the next major Windows 10 update will not kill this solution...
