Surface Pro 6 gets stuck at 0.40GHz (While charging) (SOLVED)
2019-06-23T19:00:04+00:00
I'm posting to report a bug that seems to occur on rare occasions. Every once in a while my Surface Pro 6 gets stuck at 0.40GHz while it's plugged to the adapter but works fine on battery. I've had this issue occur about 4-5 times throughout the 6 months I've owned it. The only fix for this issue is re-installing the Surface Pro 6 firmware. I think it's more firmware related than hardware, or maybe the chip that holds the firmware is defective? Anyways, I thought I'd report this issue because it still needs fixing.
SOLVED - This was fixed with the latest (Nov) firmware update.
2019-10-25T03:04:31+00:00
Thank you for reporting the issue.
A fix for this issue is currently available through our Release Preview ring in the Windows Insider Program.  When joining the Windows Insider program you will stay on a retail build of Windows, but get a sneak peek at on-going development of apps, drivers, and other quality updates.  As of the date of this post, Release Preview installs Windows 10 version 1909.  In addition, you will also receive prerelease updates for Surface before they are more broadly available.  The Windows Insiders program is designed exclusively for people who want to be involved in the process of trying out new updates before the final release to everyone.
To join the Windows Insider Program go to Settings> Update & Security > Windows Insider Program and click Get Started.  You will need to provide a Microsoft Account and when prompted choose Release Preview. You can always go to Settings> Update & Security > Windows Insider Program to opt out of receiving preview updates.
This fix will be generally available through Windows Update as soon as it completes our quality testing.
51 additional answers
    2019-09-09T16:50:16+00:00
    Mines also under warranty, but I've read on community forums that the replacements had the same problem. I may have mines replaced a month before the warranty is up, but It seems like a waste of time. Maybe you can report back if it solved the problem, but many people have said the replacements had the same problem after a while. If it is a hardware issue, I hope Microsoft issues a hardware recall. I don't plan on buying another one unless we see a fix. I don't want to risk more money on a device with major issues.
    2019-09-09T17:53:21+00:00
    Thanks.  Will keep you posted.  Might take some time to get through the reinstall and testing to see if the issue occurs.  I wish there were some way to log the Prochot status in the event viewer so that I don't have to track it.
    2019-09-11T18:20:13+00:00
    This works for me on my Surface Pro 6.  I get the throttling several times a day.  Usually Chrome is the only thing running.
    Disconnect power.  Reconnect power.  CPU jumps back up and stays there.  For a little while anyway.
    Not a great fix, but seems to be working for now.
    2019-09-11T19:49:09+00:00
    Got same issue here
