Surface Pro brightness bug
2013-02-19T02:05:17+00:00
The surface pro randomly brightens and dims even when auto brightness and dimming is completely shut off.  I contactedMicrosoft chat support and they said they are aware of the issue but its taking longer than expected.  I just wanted to post here to create more visibility and awareness of this annoying bug.  I hope it gets fixed soon.   Its most noticeable when an app launches or while beginning to watch a video.  From what I've heard it happens with RT too.
2013-03-15T17:19:47+00:00
Great news folks! I was able to fix this issue!!!!! :-D
So the issue appears to be the Intel HD 4000 implementing 2 forms of battery saving contrast adapting. But we have no ability to change these settings by default.
So first of all make sure your dynamic brightness is turned off in your PC Settings and/or battery plan. Then...
Go Intel's site and download and then install the latest driver for the Intel HD Graphics 4000.
I believe this is the correct link -
EDIT: Oops my link was for the 32 bit driver. This is the one you need -
http://downloadcenter.intel.com/Detail\_Desc.aspx?agr=Y&DwnldID=22375&lang=eng&wapkw=intel%C2%AE+hd+graphics+driver+for+windows+7\*+and+windows+8\*+%28exe%29
This should give you access to the Intel Graphics and Media Control panel when you right click and select Graphics Properties from the desktop.
Select ADVANCED MODE
GOTO > MEDIA > IMAGE ENHANCEMENT and disable "Adaptive Contrast Enhancement"
Then GOTO > POWER > Change POWER SOURCE to "On Battery" and make sure "Display Power Saving Technology" is disabled (that is unchecked).
Click APPLY and viola no more dynamic contrast annoyances!
YAY!
2013-03-09T20:02:42+00:00
Greetings Gary,
Thank you for letting us know. Can you by chance get a video of it happening as this is something we are looking into.
119 additional answers
    2015-01-20T17:08:16+00:00
    Okay. This is a video demonstration of flickering. Recorded on DSLR camera with constant ISO, aperture and shutter speed.
    If you wanna repeat this on your surface please use: http://pastebin.com/LKVXdrkH
    Save as html and open in browser in fullscreen mode. Press any key for toggle of right side.
    2015-01-20T17:25:53+00:00
    Oh, this is great! And completely crazy... especially if you compare it with any other device.
    Maybe you'd create a Luser-Version for Microsoft with automatic changes of the right side and a text like "the color on the left side should always stay the same". Then we'd try to get through to some guys who are responsible.
    The lady on the hotline wasn't too interested when I told her the solution and mentioned that I did not have to reset or send in my device (like she suggested).
    Concerning the video: Well mine demonstrates the flickering in a normal movie, but yours certainly optimizes the demonstration of this effect!
    2015-01-29T22:52:28+00:00
    Concerning the issue with "driver not verified for this computer" I just had to uninstall the driver for the Intel HD 4400 in the device control and then I was able to re-install the signed Intel driver where it is possible to deactivate these nasty powersafe options.
