Surface Pro brightness bug
2013-02-19T02:05:17+00:00
The surface pro randomly brightens and dims even when auto brightness and dimming is completely shut off.  I contactedMicrosoft chat support and they said they are aware of the issue but its taking longer than expected.  I just wanted to post here to create more visibility and awareness of this annoying bug.  I hope it gets fixed soon.   Its most noticeable when an app launches or while beginning to watch a video.  From what I've heard it happens with RT too.
2013-03-15T17:19:47+00:00
Great news folks! I was able to fix this issue!!!!! :-D
So the issue appears to be the Intel HD 4000 implementing 2 forms of battery saving contrast adapting. But we have no ability to change these settings by default.
So first of all make sure your dynamic brightness is turned off in your PC Settings and/or battery plan. Then...
Go Intel's site and download and then install the latest driver for the Intel HD Graphics 4000.
I believe this is the correct link -
EDIT: Oops my link was for the 32 bit driver. This is the one you need -
http://downloadcenter.intel.com/Detail\_Desc.aspx?agr=Y&DwnldID=22375&lang=eng&wapkw=intel%C2%AE+hd+graphics+driver+for+windows+7\*+and+windows+8\*+%28exe%29
This should give you access to the Intel Graphics and Media Control panel when you right click and select Graphics Properties from the desktop.
Select ADVANCED MODE
GOTO > MEDIA > IMAGE ENHANCEMENT and disable "Adaptive Contrast Enhancement"
Then GOTO > POWER > Change POWER SOURCE to "On Battery" and make sure "Display Power Saving Technology" is disabled (that is unchecked).
Click APPLY and viola no more dynamic contrast annoyances!
YAY!
2013-03-09T20:02:42+00:00
Greetings Gary,
Thank you for letting us know. Can you by chance get a video of it happening as this is something we are looking into.
119 additional answers
    2014-04-20T22:39:11+00:00
    And is this problem also found on the other Windows 8 tablet... the Dell Venue and such ?
    2014-04-22T15:12:09+00:00
    If they use the Intel HD 4000, most likely. Although it may just be that MS use their own driver for it that blocks off the control panel. With access to the Intel HD control panel, this issue is fixed in seconds.
    2014-04-22T22:43:34+00:00
    I turned auto brightness off for when plugged in and on battery.
    The screen continues to brighten and dim.
    I had been suspecting that the power cable was at fault.
    I tried cleaning the terminals on the Surface Pro and the connector on the cable.
    No change.
    I later notice the LED light on the connector was turning on and off as I moved the cable.
    I think the cable is damaged.
    I wonder if this is covered by the warranty by MS?
