Surface Pro brightness bug
2013-02-19T02:05:17+00:00
The surface pro randomly brightens and dims even when auto brightness and dimming is completely shut off.  I contactedMicrosoft chat support and they said they are aware of the issue but its taking longer than expected.  I just wanted to post here to create more visibility and awareness of this annoying bug.  I hope it gets fixed soon.   Its most noticeable when an app launches or while beginning to watch a video.  From what I've heard it happens with RT too.
2013-03-15T17:19:47+00:00
Great news folks! I was able to fix this issue!!!!! :-D
So the issue appears to be the Intel HD 4000 implementing 2 forms of battery saving contrast adapting. But we have no ability to change these settings by default.
So first of all make sure your dynamic brightness is turned off in your PC Settings and/or battery plan. Then...
Go Intel's site and download and then install the latest driver for the Intel HD Graphics 4000.
I believe this is the correct link -
EDIT: Oops my link was for the 32 bit driver. This is the one you need -
http://downloadcenter.intel.com/Detail\_Desc.aspx?agr=Y&DwnldID=22375&lang=eng&wapkw=intel%C2%AE+hd+graphics+driver+for+windows+7\*+and+windows+8\*+%28exe%29
This should give you access to the Intel Graphics and Media Control panel when you right click and select Graphics Properties from the desktop.
Select ADVANCED MODE
GOTO > MEDIA > IMAGE ENHANCEMENT and disable "Adaptive Contrast Enhancement"
Then GOTO > POWER > Change POWER SOURCE to "On Battery" and make sure "Display Power Saving Technology" is disabled (that is unchecked).
Click APPLY and viola no more dynamic contrast annoyances!
YAY!
2013-03-09T20:02:42+00:00
Greetings Gary,
Thank you for letting us know. Can you by chance get a video of it happening as this is something we are looking into.
119 additional answers
    2013-03-12T23:40:50+00:00
    I don't count it as a bug because as soon as I disables the auto brightness off the dim thing never happened. I have not uninstalled any sensor driver or anything. You guys just need to disable the auto brightness off in settings.
    2013-03-13T01:17:58+00:00
    For many, the auto-dimming/brightness continues despite it being turned off. It is definitely a bug that Microsoft has acknowledged.
    2013-03-13T15:29:45+00:00
    I agree, was really hoping the fix would come in this march updates :(
