Hi, it appears you may have a faulty device. Outside the pressure issue, jitter should not be a problem on the surface pro 7. Can you show me what surface pen you are using?
Surface Pro 7 pen pressure issues with palm rejection
Pen works fine when only the pen is making contact with the screen. However, when my palm is resting on the screen, the pressure detection of the pen becomes extremely inaccurate. As soon as skin (palm, fingers, etc) makes contact with the screen, the pressure curve of the pen becomes a staircase, as if the pen could only detect 5-20 levels of pressure, instead of 4096 like it's supposed to. Here's a screenshot from the Surface app:
OS: Windows 10 Home Version 1903 build 18362.449 (edit: I've since updated to 1909 build 18363.628, issue persists)
Pen: Microsoft Surface Pen Model 1776 (Burgundy)
I have:
- paired my pen
- unpaired and repaired the pen via Bluetooth options
- rebooted the Surface Pro
- soft reset the Surface Pro (volume+ and power buttons down for 15 seconds)
- removed and reinserted the battery into the pen (only way I could think of turning it off and on again)
- checked Windows Updates
- checked for app updates via Windows Store
- run the Surface Diagnostic Toolkit, no problems detected
- tried with and without Settings → Devices → Pen & Windows Ink → Ignore touch input when I'm using my pen
- set the correct hand I'm using from pen settings
- tried in multiple different apps, including Surface app, Adobe Photoshop, Krita, Sketchable, Autodesk SketchBook and others — same problem everywhere
- tried calibrating the pen (search "calibrate" from start menu and choose pen calibration), a dialog opens after choosing "Calibrate..." → "Pen input", asks for permission, and just makes a sound and closes after I grant permission, so I'm not sure if it's not working correctly, but nothing changed either way — tried to do this multiple times, rebooting in between, but doesn't seem to do anything
2020-02-10T20:24:36+00:00 -
2020-02-10T20:23:09+00:00 Hi, in my experience jitter is not an issue with the surface pro 7. Compared to surface book 2 (which is basically unusable), accuracy and jitter is greatly improved. Which surface pen are you using?
2020-02-10T20:12:42+00:00 Hi
I have the same problem on my SP7 (i5, 16GB, 256)
I had such high hopes for this device but now I'm really disappointed.
For years I had a laptop and a tablet and finally wanted to combine the two but now ... :(
I've found out that the jitter is considerably worse when there is power connected to the surface. Anything electrical (e.g. even a projector) will make the jitters unbearable!!
Also I live in Iran and aside from the astronomical price of the device here, there is no Microsoft support! So basically if this thing is not fixable via a software update, I'm screwed!
Has any body found a fix for this yet?
2020-02-07T22:28:56+00:00 Hi all! I also had the misfortune to buy this device. The line of my pen also performs dances and nothing helps me...
It is unfortunate that I was so deceived. I am also an artist.
I buy Surface pro 7...
2020-01-15T13:46:30+00:00 Follow-up from my previous post,
Every single Surface Pro 7 and Surface Pro X I checked there had this issue. I chatted with a store clerk about it and he told me he's going to escalate the issue, but I wouldn't hold my breath.
Here is another example of the issue on the Surface Pro X and 7.
This is a major issue for artists, since not only does this happen when resting your palm, but any touch interaction, such as when using brush modifiers with your thumb, while drawing with the pen.
Apparently, the Surface Laptop 3 seems to also be affected.
