Surface Pro 7 pen pressure issues with palm rejection
2019-11-01T19:50:11+00:00
Pen works fine when only the pen is making contact with the screen. However, when my palm is resting on the screen, the pressure detection of the pen becomes extremely inaccurate. As soon as skin (palm, fingers, etc) makes contact with the screen, the pressure curve of the pen becomes a staircase, as if the pen could only detect 5-20 levels of pressure, instead of 4096 like it's supposed to. Here's a screenshot from the Surface app:![](https://learn-attachment.microsoft.com/api/attachments/cdc3b0c5-bfcc-4409-b0a1-318885287f48?platform=QnAAnd here is how it looks like when drawing:
Is this normal? How can I fix it?
Device: Surface Pro 7 Model 1866 i5 (8GB RAM, 128GB SSD)
OS: Windows 10 Home Version 1903 build 18362.449 (edit: I've since updated to 1909 build 18363.628, issue persists)
Pen: Microsoft Surface Pen Model 1776 (Burgundy)
I have:
  • paired my pen
  • unpaired and repaired the pen via Bluetooth options
  • rebooted the Surface Pro
  • soft reset the Surface Pro (volume+ and power buttons down for 15 seconds)
  • removed and reinserted the battery into the pen (only way I could think of turning it off and on again)
  • checked Windows Updates
  • checked for app updates via Windows Store
  • run the Surface Diagnostic Toolkit, no problems detected
  • tried with and without Settings → Devices → Pen & Windows Ink → Ignore touch input when I'm using my pen
  • set the correct hand I'm using from pen settings
  • tried in multiple different apps, including Surface app, Adobe Photoshop, Krita, Sketchable, Autodesk SketchBook and others — same problem everywhere
  • tried calibrating the pen (search "calibrate" from start menu and choose pen calibration), a dialog opens after choosing "Calibrate..." → "Pen input", asks for permission, and just makes a sound and closes after I grant permission, so I'm not sure if it's not working correctly, but nothing changed either way — tried to do this multiple times, rebooting in between, but doesn't seem to do anything
    2019-11-06T18:31:32+00:00
    Hi, is this happening both on battery and PSU is plugged in? Would it be possible for you to
    visit Microsoft Store to have our Technician there reproduce the issue since our Surface Pro 7 and Version 4 Pen here had no issues and looks good in writing.
    2019-11-06T10:36:28+00:00
    Can you use the Feedback Hub App to file a problem report and use the share
    function to get a link and post that link here in a reply so others can upvote?
    2019-11-05T21:23:20+00:00
    please feel free to reach out to me directly as well as in this thread. Thank you
    Justice
    Tablet Pro
    https://www.tabletpro.com
    ******@tabletpro.com
    2019-11-05T16:55:01+00:00
    I really appreciate the efforts. Is this happening both when PSU is plugged in and on battery? To reproduce the issue, can you sit the device on your lap and try to write without accessories connected except for your Surface Pen? If issue persist, try to change the battery with a brand new one. Other way to isolate is test another brand new pen on your Surface or test your Pen on a different Surface.
    2019-11-02T07:46:38+00:00
    Thanks for your reply! I ran the Diagnostic Tool again now just to be sure. Just like before, it didn't find anything.
    From Device Manager, I uninstalled almost all HID devices just to be sure, not just ones that said touch/pen/ink. It started adding them back after I had uninstalled almost everything. I rebooted. The problem still persists.
    Anything else I could try?
