Surface Pro 7 pen pressure issues with palm rejection
2019-11-01T19:50:11+00:00
Pen works fine when only the pen is making contact with the screen. However, when my palm is resting on the screen, the pressure detection of the pen becomes extremely inaccurate. As soon as skin (palm, fingers, etc) makes contact with the screen, the pressure curve of the pen becomes a staircase, as if the pen could only detect 5-20 levels of pressure, instead of 4096 like it's supposed to. Here's a screenshot from the Surface app:![](https://learn-attachment.microsoft.com/api/attachments/cdc3b0c5-bfcc-4409-b0a1-318885287f48?platform=QnAAnd here is how it looks like when drawing:
Is this normal? How can I fix it?
Device: Surface Pro 7 Model 1866 i5 (8GB RAM, 128GB SSD)
OS: Windows 10 Home Version 1903 build 18362.449 (edit: I've since updated to 1909 build 18363.628, issue persists)
Pen: Microsoft Surface Pen Model 1776 (Burgundy)
I have:
  • paired my pen
  • unpaired and repaired the pen via Bluetooth options
  • rebooted the Surface Pro
  • soft reset the Surface Pro (volume+ and power buttons down for 15 seconds)
  • removed and reinserted the battery into the pen (only way I could think of turning it off and on again)
  • checked Windows Updates
  • checked for app updates via Windows Store
  • run the Surface Diagnostic Toolkit, no problems detected
  • tried with and without Settings → Devices → Pen & Windows Ink → Ignore touch input when I'm using my pen
  • set the correct hand I'm using from pen settings
  • tried in multiple different apps, including Surface app, Adobe Photoshop, Krita, Sketchable, Autodesk SketchBook and others — same problem everywhere
  • tried calibrating the pen (search "calibrate" from start menu and choose pen calibration), a dialog opens after choosing "Calibrate..." → "Pen input", asks for permission, and just makes a sound and closes after I grant permission, so I'm not sure if it's not working correctly, but nothing changed either way — tried to do this multiple times, rebooting in between, but doesn't seem to do anything
    2020-08-18T11:30:57+00:00
    It's alright! Thank you for informing us about the update, however. I'm sure many of us were relieved to have heard about this. ^_^ I sure was relieved when I saw your post.
    2020-08-18T11:28:40+00:00
    This is actually great news! This means that the problem can be fixed through software and the fix won't be too far for us SP7 users. Hopefully they also fixed the worsening jitter when palm is on-screen. ^_^
    Thank you so much for this one! This actually made my worry go away. <3
    2020-08-17T11:20:41+00:00
    See screenshots from surface app. I am on insider Dec channel.
    2020-08-17T11:10:23+00:00
    Unfortunately, it's still there. :[
    Could you send us a screenshot of the fixed pen pressure curve? Because if that's true, then that means there is hope that Microsoft will fix it sooner or later for the SP7 users.:D
    Ohhh that sucks.
    Sadly the X does not have the Apps i need.
    2020-08-15T22:07:18+00:00
