Will be interested what happens. In my case it was escalated but the same reply came back spend the money and we will replace the device, don't spend the money, then there is nothing we (Microsoft) are prepared to do. Pretty appalling from a huge multinational with a defective product that represents a fire hazard. An automobile manufacturer would not get away with such a cavalier attitude, there would have been a recall long ago.
Surface Pro 4 Bulging Battery / Screen. 3 1/2 years old.
So, like many others on this forum, we have a Surface Pro 4, in which the battery has decided to self-destruct, destroying a £1,700 machine.
The screen hasn't popped off, but the battery has swollen enough to prevent the hinge from opening as it should and for the glass on the front to be very distorted, and it registers random screen input, all the while running hotter than the central heating.
I've spoken to support. They unhelpfully told me that because my warranty is up, I would have to pay several hundred pounds (£333) to replace the machine with a refurbished unit. To me, this is completely unacceptable. These devices are clearly flawed by design. This issue is too wide spread for it to be a coincidence. The batteries used in these devices are obviously flawed, and when I suggested as such, Sean L, the person dealing with my case, stopped responding (A few days after that, I wrote to Microsoft's twitter support who confirmed that the case had been closed. Thanks Sean L.)
If the device is dangerous (as suggested by the agent who I spoke to on the phone in the first instance) and it does catch fire while we are away this summer, and it subsequently burns down a multi-million pound Cambridge University building? What then, Microsoft? You'll wish you'd just replaced it then, won't you.
2020-10-21T17:55:34+00:00 -
2020-10-21T23:05:05+00:00 Exactly the same here .
Swollen battery is a fire hazard (that's when the battery stops storing energy and starts conducing it, generating extreme heat and eventually exploding /catching fire (remember how some Samsung devices were banned on planes even if they were off?)
So, two options.
- stop using it and buy a 2 in 1 devices like Dell, Lenovo or hp. Basically move on.
- take it to a place were they can replace the battery. Its not cheap, but way cheaper than buying a new computer. Specially if the screen is not cracked.
I did option 2 and is working fine (for 300Au dollars). I reckon it will last me ?2 more years and then go to option 1.
My screen was brown like yours and some areas not working. After replacing the battery, everything started working again just fine. The guy in the shop told me that it was the 7th Surface in the month he had fixed.
Good luck.
2020-10-21T23:08:12+00:00 I experienced the yellow spots all around the screen and some bulging. Finally the screen split from the frame and left a 4 inch long gap (it's growing), which relieved the pressure. Now all of the spots are gone, but I'll never be able to close the Surface and I don't know what will happen if something falls inside the huge hole on top of my display.
I refused to pay the $590 asked, but it didn't faze the person on the phone. I understand it's not their policy, but the all-or-nothing attitude was off-putting, to say the least.
Good luck, Magdy, with your efforts.
2020-10-22T02:13:06+00:00 Hope you're not holding your breath until you get satisfaction.
It's unfortunate that a great machine comes with such awful customer service.
2020-10-30T06:05:23+00:00 Hello all, this is an update on how Microsoft responds to our concerns relative to its battery issue in its Surface Pro 4.
As many of you reported, Microsoft refuses to substitute its defective Surface 4 Pro for free, if the battery bulges after three years from purchase.
Instead, given Microsoft considers Surface 4 a Legacy device, so it offers to upgrade the Surface to a newer model (not specified which one), for ~650 euros!
About the problem, Microsoft denies any responsibility on the battery issue, saying that this 'happens with different devices that has lithium batteries like phone ,tablets and other devices'.
Well, sorry Microsoft, but none of my tablets, mobiles, or other Surfaces (I have a 3 and a 5) have never behaved similarly.
It adds that 'There is no inherent risk or safety concern associated with these expanded batteries' yet '...the lithium ion batteries used in Surface devices contain materials that can injure skin, eyes, and lungs if punctured.'
Amusing isn't it? It's not risky but Microsoft eventually suggests to use its Surface Pro 4 wearing glasses and a mask. Amazing how, bacy in 2015, Microsoft already engineered a Surface ready for COVID-19 times.
In the meantime, my Surface...is expanding... is it fair to say that Microsoft is not customer oriented?
