how can fix Microsoft Modern Wireless headset that does not have sound even though the whitelight is on?
2022-01-20T08:36:29+00:00
hi,
My Microsoft Modern Wireless headset just stopped working while I am watching some youtube video. I got no sound from it. It still connected to my PC with attached USB Link that came with the headset.
Somehow the white light on the headset is on, even I switched it off and without connected to a usb-c cable. Very strange and looks like it just froze.
It is a great headset and please help.
Kevin
Surface | Surface Headphones | Settings
2022-04-19T22:38:18+00:00
I was suffering with the same issue, but solved it with these steps:
  1. Turn off the headset
  2. Plugged the headset in a cellphone charger (USB-C 20W)
  3. Turn on the headset
  4. Press and hold the Bluetooth and call buttons together for 10 seconds
I don't know if all the steps are necessary, maybe just using the charger is the catch. Good luck everyone!
Ref: Set up Microsoft Modern Wireless Headset - Microsoft Support
29 additional answers
    2022-09-12T16:46:56+00:00
    It Works!!
    My headset turned off finally
    Thanks!
    Yes, looks like the trick is the charger
    2022-09-22T00:20:08+00:00
    It worked!
    2022-11-24T22:33:56+00:00
    I am having this issue now as well. Based on the comments it seems the only thing would be to wait for the battery to drain and see if that makes it work again. :(
    2022-12-21T17:07:07+00:00
    Thanks for sharing Victor.
    I tried charging the headset off overnight and the white light still was on this morning. The phone and blue tooth button for 10 seconds reset worked.
