how can fix Microsoft Modern Wireless headset that does not have sound even though the whitelight is on?
2022-01-20T08:36:29+00:00
hi,
My Microsoft Modern Wireless headset just stopped working while I am watching some youtube video. I got no sound from it. It still connected to my PC with attached USB Link that came with the headset.
Somehow the white light on the headset is on, even I switched it off and without connected to a usb-c cable. Very strange and looks like it just froze.
It is a great headset and please help.
Kevin
Surface | Surface Headphones | Settings
2022-04-19T22:38:18+00:00
I was suffering with the same issue, but solved it with these steps:
  1. Turn off the headset
  2. Plugged the headset in a cellphone charger (USB-C 20W)
  3. Turn on the headset
  4. Press and hold the Bluetooth and call buttons together for 10 seconds
I don't know if all the steps are necessary, maybe just using the charger is the catch. Good luck everyone!
Ref: Set up Microsoft Modern Wireless Headset - Microsoft Support
29 additional answers
    2022-07-01T20:20:46+00:00
    This worked for me after having the same issue. Thanks.
    2022-07-13T18:07:52+00:00
    Esto funciona
    Gracias
    Genio
    2022-08-11T19:28:11+00:00
    So this helped, but after the mute button no longer works, It is up to date have gone through all troubleshooting steps and still cant get the mute button to work now
    2022-08-23T02:31:37+00:00
    Thank you Victor - just did that and it reset - again no other guidance on this except yours so thanks!
