Surface Pro 3 Wavy diagonal lines when inking
2014-07-12T07:29:27+00:00
I've noticed a problem with my surface pro 3 that I have not been able to work around.  When I draw a slow diagonal line, it comes out very wavy and jagged.  If I quickly draw a diagonal, it seems ok.  Has anyone else seen this, is there a fix for it?  seems to happen in every application, so it strikes me as potential hardware.
    2014-10-15T19:23:15+00:00
    Apparently Microsoft doesn't monitor it's own threads.
    2014-10-17T14:34:06+00:00
    Wacom is the industry standard for a reason. A thinner optical layer is NOT worth sacrificing pen accuracy at this kind of scale.
    2014-10-17T16:39:15+00:00
    Good to know.
    I've been researching this issue 'cause I have to buy a new computer but I also need some compact digitizer screen that I can carry, but I can tell this wavy line issue pulled me down.
    There is nothing to do with it. It's not driver problem, it is poor hardware. I have used numerous tablets, screens, mostly Wacom ones. Although my first one was a nice big Trust tablet, that suffered from the same issue. I installed the fresh driver, re-installed over and over again, and in the end I returned the tablet 'cause I thought that was a faulty one, the replacement was the same. They were nice at the shop, gave me back my money and I purchased Wacom. Had been solved.
    2014-11-03T18:37:32+00:00
    I was able reduce jitter using a screen protector (this matte Tech Armor in particular) which increased the friction between the pen and the surface, and brought the experience a bit closer to my previous Wacom tablets.
    There aren't too many alternative pen options, but this HTC stylus is also Ntrig and works with the SP3. It has a different feel to it, more friction and perhaps lower activation force. A bit clicky though, and no bluetooth button.
    There is also third-party software out there now that allows remapping of the hard/soft buttons on the SP3 as well as the pen (or you can write your own with Autohotkey + EventGhost) and Ntrig has an updated WinTab driver. I guess it sucks that the customer has to work a bit to get something working just to be on par with previous levels, but things seem reasonable enough with inking that I'm keeping my SP3 with its gorgeous screen and aspect ratio.
    2014-11-03T18:48:43+00:00
    Can you post a picture of your diagonal lines to see how it looks with the new screen protector?
