I got the new surface pen for my surface pro 3, and it goes a long way to improve the writing experience. It definitely seems to be some kind of grounding issue, because I've noticed that the issue almost seems to go away when I am holding the SP3 against some part of my body, or I touch the back of it when it stands on its own. The moment my drawing hand is the only part of my body touching the surface, it seems to get way worse. Can anyone else confirm this?
Surface Pro 3 Wavy diagonal lines when inking
I've noticed a problem with my surface pro 3 that I have not been able to work around. When I draw a slow diagonal line, it comes out very wavy and jagged. If I quickly draw a diagonal, it seems ok. Has anyone else seen this, is there a fix for it? seems to happen in every application, so it strikes me as potential hardware.
Deleted
2016-02-12T15:40:52+00:00 -
Deleted
Deleted
2016-03-09T21:23:02+00:00 Hello all
Thank you for reporting and keeping us up to date on specific details. We are currently investigating.
Best regards
Hello John
whats was the outcome of your investgations?
Why didn't you pass feedback to us ?
Thanks for letting us know
