On Sat, 11 Apr 2015 21:18:37 +0000, Chacone88 wrote:
>>I bought a 128gb Sandisk SDXC for my surface pro 3 i5 128gb last month. this microSD card can work well for about few hours then I can't see the icon of SDXC card in my computer. Thus, I have to replug in it several times a day. I tried to test this card in other PC and it worked well for all day. Moreover, my surface pro 3 is always up to date. Can anyone give me a solution for this problem?
There have been reports from others like this. Some find that it is the
particular SDXC card and a replacement/other brand work as they should in the
SP3. Some folks have actually returned their SP3's/exchanged them (depending if
it is brand new or not as you will get a refurb replacement).
It's unknown why these sometimes unmount randomly.
Some threads on this:
http://www.reddit.com/r/Surface/comments/29dkxp/just_got_the_sandisk_128_gb_card_for_my_sp3_and/
http://www.surfaceforums.net/threads/how-i-solved-my-sdcard-unmounting-problem.4763/
http://forum.tabletpcreview.com/threads/anyone-else-having-problems-with-microsd-card-dismounting.61215/
Depending on when and where you bought the card, see if you can exchange it
(there is some evidence that there are batches of cards that are good or bad).
Barb
Windows Experience MVP
