Surface Pro 4 Incompatibility with Ultra-wide Monitor
2016-04-12T04:59:50+00:00
Last year I had purchased a brand new Samsung 29" ultra-wide curved LED monitor S29E790C to use with my older Surface Pro 2, and it worked like a charm. I would have it set to only display on the external display, and the graphics ran smoothly. However, much to my dismay, when I bought a brand new Surface Pro 4 (256 GB, i5, 8GB RAM model), the external monitor will, under no circumstance, adjust the native resolution properly.
The maximum option available is the 1920 x 1080 (recommended), and it's getting pretty frustrating trying to multitask using a 21:9 monitor with fat 3" black bars on either side of the active display area. I am using a regular Mini DisplayPort to HDMI adapter cable, which I have eliminated as the cause of the issue -- tried swapping it out with the other 4 identical ones I have as backups. I have heard tales of others experiencing the same exact issue with the newest design of the Surface moving to a 4:3 resolution in later models. Any input is appreciated.
2016-10-13T12:16:05+00:00
Here is my current status for connecting my ultra wide Samsung monitor to my Surface Book /Surface Dock:
I ordered 2 cables for testing - one cable is a mini display port to display port; and the second is an active mini display port to HDMI.  My monitor has a display port and 2 HDMI interfaces.
The first cable I received was the mini display port to display port and when I connected this it was a complete and immediate success!!  The monitor switched over right away and had the correct resolution of 2560x1080.  To say I was happy was an understatement.  I installed the monitor drivers for the display port and all is as it should be.
The second cable I received was the active mini display port to HDMI.  I disconnected the display port cable and plugged in this new cable and I had the same issue as with the passive mini display port to HDMI meaning it would not recognize the higher resolution so the monitor and my surface both stayed black.  All of this was the same exact issue as before.  I am not sure if the current monitor drive installed was interfering, but honestly, was not about to make more changes at this point.  I went through the typical reboot, reset the surface dock, etc, but no luck.
If you only have an HDMI port, it may be worth trying the active mini display port to see if that will work.  For my configuration, the display port seems to work the best.
2016-04-23T22:50:42+00:00
IT WORKED!
I used the display port on my LG Ultra Wide (29UM55-P), instead of HDMI, and connected it to the mini display port on the Surface Pro 4 and now I have the native resolution (2560 x 1080) again on my LG.  Looks fantastic!
Here is the cable I used:
http://www.amazon.com/Cable-Matters-DisplayPort-Thunderbolt-Compatible/dp/B00C7RJQPY?ie=UTF8&psc=1&redirect=true&ref\_=oh\_aui\_detailpage\_o00\_s00
If you have a monitor that is not working with HDMI-to-MiniDisplayPort adaptors on the Surface Pro 4 I recommend going display port with cable.
Good luck all!
47 additional answers
  1. Deleted
    2016-04-23T20:42:53+00:00
    Best of luck with the cable, I'm going to try and find a friend with the dock and see if that resolves the issue.
    2016-04-23T20:37:19+00:00
    Ok, trying the Microsoft recommended Cable Matters Display Port to Mini Display Port Cable.  It should be here today thanks to Amazon Prime.  :-)  I will update this thread once I get it hooked up.
