Visual Studio 2022 won't connect to NuGet
mindmischief 41 Reputation points
2022-08-08T17:50:50.513+00:00
Visual Studio 2022 gives an error when trying to browse NuGet.
I get these errors on 2 different Windows Servers (2016) I’ve tried. One running Visual Studio 2017, the other running Visual Studio 2019 and 2022.
Visual Studio 2017:
“[nuget.org] Unable to load the service index for source https://api.nuget.org/v3/index.ison.
An error occurred while sending the request.
The underlying connection was closed: An unexpected error occurred on a send.
Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
An existing connection was forcibly closed by the remote host.”
Visual Studio 2022:
[nuget.org] Unable to load the service index for source https://api.nuget.org/v3/index.json. An error occurred while sending the request. The underlying connection was closed: An unexpected error occurred on a send. Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. An existing connection was forcibly closed by the remote host
Note that we do not use a proxy.
Loading https://api.nuget.org/v3/index.json with both Chrome and Edge work.
Loading https://api.nuget.org/v3/index.json with Internet Explorer returns:
“This page can’t be displayed
Turn on TLS 1.0, TLS 1.1, and TLS 1.2 in Advanced settings and try connecting to https://api.nuget.org again. If this error persists, it is possible that this site uses an unsupported protocol or cipher suite such as RC4 (link for the details), which is not considered secure. Please contact your site administrator.”
Things I’ve tried that have failed to resolve it
updated Visual Studio
Clearing nuget cache from within Visual Studio
Deleted NuGet.Config from C:\Users\<user>\AppData\Roaming\NuGet
Modified C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\devenv.com based on tips I found. I know it’s possible that what I changed was not correct. Reverted back.
Registry changes:
Computer\HKEY LOCAL MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.0\Client
Computer\HKEY LOCAL MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.1\Client
Computer\HKEY LOCAL MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.3\Client
DisabledByDefault = 1
Enabled = 0
Computer\HKEY LOCAL MACHINE\SYSTEM\ CurrentControl Set) Control SecurityProviders \SCHANNEL\Protocols\TLS 1.2\Client
DisabledByDefault = 0
Enabled = 1
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft.NETFramework\v2.0.50727
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft.NETFramework\v4.0.30319
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft.NETFramework\v2.0.50727
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft.NETFramework\v4.0.30319
SchUseStrongCrypto = 1
SystemDefaultTlsVersions = 1
Tried moving the server's Active Directory object out of the current AD OU which has a Group Policy configured with specific ciphers enabled, and the order of preference, into a new OU with this NOT configured.
Tried disabling anti-virus software
Reference links, things I've tried or looked into:
https://learn.microsoft.com/en-us/security/engineering/solving-tls1-problem
https://learn.microsoft.com/en-us/troubleshoot/azure/active-directory/enable-support-tls-environment?tabs=azure-monitor%22%20%5Cl%20%22registry-strings
https://stackoverflow.com/questions/41185443/nuget-connection-attempt-failed-unable-to-load-the-service-index-for-source
At this point, I'm run out of ideas. It seems like Visual Studio is not adhering to the system's default TLS settings (1.2) but it could possibly be something else.
Developer technologies | Visual Studio | Setup
Developer technologies | .NET | Other
Sly, Jack 96 Reputation points
2022-08-09T14:53:41.39+00:00
We had this issue today, this was resolved out end by adding TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 into HKLM\SOFTWARE\Policies\Microsoft\Cryptography\Configuration\SSL\00010002
Also ensured only 'Use TLS 1.2' was enabled in IE Options, and no proxy settings were set up.
Hope this helps.
8 additional answers
  1. mindmischief 41 Reputation points
    2022-08-09T20:49:59.787+00:00
    I posted this question on an internal Slack channel and someone responded there with a similar reply.
    I added these two to our GPO and it fixed it.
    TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
    Thanks for your help!
  2. Paul Walton 1 Reputation point
    2022-09-25T12:20:03.52+00:00
    @Vincent Castagna I have the same question. The frequent use of initialisms is annoying. I think GPO is referring to Group Policy Objects but I'm not sure.
    Like you also asked, it would be helpful if they explained how they added these keys to the registry.
  3. Alexander Dunn 1 Reputation point
    2022-10-24T16:08:59.447+00:00
    I had a very similar issue and so did what @Sly, Jack and @mindmischief recommended
  4. Thomas Grossi 6 Reputation points
    2022-12-05T14:03:11.463+00:00
    For anyone hitting a 401, about a week after changing my corporate password all Visual Studio versions started using old credentials. Deleting all the credentials cached in Credential Manager (search for it in the start menu) fix me up. I never knew that existed, but thankfully our help desk did!
