Thanks for posting here.
In general, there are several reasons may cause upload speed slow.
I would suggest you try the following method to see if the upload speed can be returned to normal.
Option 1
Open Control Panel > Network and Sharing Center > Change adapter settings > Right click the adapter that you need check > click Properties > click Configure > in Advanced tab, locate to Speed & Duplex > select the value 10 Mbps Half Duplex > click OK to see if the issue can be resolved.
Option 2
Press Windows+R to open Run, insert gpedit.msc, click OK to open Local Group Policy Editor > Computer Configuration > Administrative Templates > Network > QoS Packet Scheduler > right click Limit reservable bandwidth > click Edit > select Enable and set Bandwidth limit to 0 > click Apply and OK
Option 3
Click Start, insert cmd to open a CMD window with administrator privilege and please insert the following command and press enter
netsh interface tcp set global autotuning=disabled
Then in the same CMD window, insert command regedit to open Registry Editor
Locate to HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\services\AFD\Parameters
Right click to create a new DWORD Value, Value name: DefaultSendWindow, Value data: 1640960, Decimal.
Click OK and Reboot the machine to see if the issue can be resolved.
Option 4
Repeat the first two steps of Option 3 to open the Registry Editor
Locate to HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings
Right click to create a new DWORD Value, Value name: SocketSendBufferLengt, Value data: 4000, Hexadecimal.
Best Regards,
Sunny Qi
If the Answer is helpful, please click "Accept Answer" and upvote it.
