Images copied from chat is not copied to clipboard? Not able to paste it in other applications
Andreas Ström 281 Reputation points
2022-05-20T09:23:19.32+00:00
I have Microsoft Teams Version 1.5.00.11163 (64-bit). It was last updated on 2022-05-13.
Repro
  1. Open Teams chat with an image pasted in the chat
  2. Click the image to enlarge the view
  3. Right click image and select "copy image"
  4. Open other application, such as MS Paint or Word
  5. Hit ctrl+v to paste iamge
Expected result: Image is pasted into application
Actual result: Nothing happens
Image is not properly copied to clipboard?
This is really anoying.
  1. TheBestPessimist 0 Reputation points
    2024-04-12T11:34:26.83+00:00
    This is still an issue. Let us copy AN IMAGE not A STRING.
    Do the people who make decisions for Feces even know what an image is? Have you ever browsed the internet?
  2. Rob Keough 0 Reputation points
    2024-06-11T14:17:13.6933333+00:00
    Piling on here, Microsoft. One Note also a no go. Also a Microsoft product. Compatibility between native apps should be a given. Still love you. Please fix.
  3. 宁川 杨 0 Reputation points
    2025-07-31T05:16:25.8866667+00:00
    Annoying, right? I had the same issue—pain in the neck. That workaround you mentioned? Yup, I’ve used it too. But it’s a band-aid fix. This shouldn’t be how C&P works. Check this out for a better option: imagetobase64</a>.image to base64
  4. Fraser Johnson 0 Reputation points
    2025-07-31T05:20:42.78+00:00
    I have Microsoft Teams version 25185.410.3812.8024 and the subject issue is no longer present. I can copy an image from teams to Microsoft Paint succesfully.
