Additional features, settings, or issues not covered by specific Microsoft Teams categories
Please fix this. I was copying images into, gmail, jira, paint etc in the 1800s
I mean who uses Word, Powerpoint etc anymore !?
Suckzord!
I have Microsoft Teams Version 1.5.00.11163 (64-bit). It was last updated on 2022-05-13.
Repro
Expected result: Image is pasted into application
Actual result: Nothing happens
Image is not properly copied to clipboard?
This is really anoying.
Suckzord!
I second everything that was said. This is a most annoying bug. You have to download the image to disk in order to be able to reused it somewhere else. Big waste of time.
This is a big pain.
See here how I workaround it: https://tdalon.blogspot.com/2023/06/workaround-copypaste-images.html
(one solution using Greenshot, the other using an autohotkey script)
Issue still persists - September 2023.
Able to copy image to Word. Not to other programs such as Paint. Have not explored all possible programs - those are just an example.
At this point you can just assume the issue is logged but not considered important enough to fix.
Teams - the unproductivity tool. When your boss asks you why you're taking so long and you tell her it took 20 minutes to figure out how to copy an image and then provide feedback into the ether.
