Azure secured hub with cross tenant Vnet peering
Oldrich Srubar 61 Reputation points
2022-05-16T15:15:49.55+00:00
I am facing one challenge in Azure networking and I am really trying to figure it out but without luck at the moment.
I have configured secured virtual hub in vWAN (Virtual WAN + Virtual hub + Azure Firewall). Thing is that there is requirement to configure cross tenant Vnet peering into secured virtual hub. I successfully managed that thanks to this Docs and some code modification:
https://learn.microsoft.com/en-us/azure/virtual-wan/cross-tenant-vnet
Peering above is not possible to configure via Azure portal so everything must be done via PowerShell. After deployment I noticed that Vnet from different tenant was successfully added into virtual network connections in Virtual WAN but I am not able to configure inspection of private traffic via Azure Firewall Manager in Security configuration deployed in this secured hub:
I wasn't able to find any PS cmdlet which can modify this settings and question is if this is even possible to configure it?
Thank you.
Azure Virtual WAN
Azure Virtual WAN
An Azure virtual networking service that provides optimized and automated branch-to-branch connectivity.
An Azure service that provides central network security policy and route management for globally distributed, software-defined perimeters.
GitaraniSharma-MSFT 50,287 Reputation points Microsoft Employee Moderator
2022-07-22T13:33:09.643+00:00
Hello @Oldrich Srubar ,
Apologies for the delay in response.
I understand that you are unable to configure inspection of private traffic via Azure Firewall in Security configuration deployed in your secured hub for the cross tenant peered Vnet.
I reproduced this issue in my lab and found that this is happening because Propogate RT was set to default in the cross tenant Vnet connection which was bypassing the Azure firewall from virtual hub to the spoke vnet.
I tried setting "Propagate to None" as Yes in the cross tenant Vnet connection but it failed with permission error as below:
So, I deleted the cross tenant Vnet connection from portal and created the cross tenant vnet connection again via Azure PowerShell using the "-RoutingConfiguration" parameter as below:
When connected to the remote/spoke subscription account:
$remote = Get-AzVirtualNetwork -Name "remotevnet" -ResourceGroupName "remoterg"
When connected to the parent/hub subscription account:
$rt1 = Get-AzVHubRouteTable -ResourceGroupName "rg1" -VirtualHubName "hub1" -Name "defaultRouteTable"
$rt2 = Get-AzVHubRouteTable -ResourceGroupName "rg1" -VirtualHubName "hub1" -Name "noneRouteTable"
$routingconfig = New-AzRoutingConfiguration -AssociatedRouteTable $rt1.Id -Label @("none") -Id @($rt2.Id)
New-AzVirtualHubVnetConnection -ResourceGroupName "rg1" -VirtualHubName "hub1" -Name "crossconnect" -RemoteVirtualNetwork $remote -RoutingConfiguration $routingconfig
Refer : https://learn.microsoft.com/en-us/powershell/module/az.network/new-azvirtualhubvnetconnection?view=azps-8.1.0#example-3
The above commands created the cross tenant vnet connection with Propagate to None option set as Yes and when I checked the Security configuration deployed in my secured hub, I could see the cross tenant Vnet secured via Azure Firewall.
Kindly let us know if the above helps or you need further assistance on this issue.
Please "Accept the answer" if the information helped you. This will help us and others in the community as well.
1 additional answer
  1. Gourav Kala 5 Reputation points
    2025-03-18T02:04:10.77+00:00
    Hi Team,
    Just wanted to check if Routing Intent is enabled on the VWAN hub for both Internet and Private Network traffic—does it also advertise the default route (0.0.0.0/0) to another tenant?
    Would this mean that all internet traffic from the other tenant would be routed through Azure Firewall due to the default route advertisement?
