A family of Microsoft word processing software products for creating web, email, and print documents.
Try these steps in order on the Mac:
- Update Office first
- Open Word.
- Select Help > Check for Updates.
- Turn on automatic updates if offered, then select Check for Updates or Update.
- Install all available Office updates, then test saving again.
- Try Save As to a new file name and location
- In Word, select File > Save As.
- Save the document with a different file name.
- If possible, save it to a different local folder on the Mac.
- This checks whether the problem is tied to the current file name or location.
- Save in a different format temporarily
- Select File > Save As.
- In File Format, choose Word Document (.docx) if the file is older, or choose another compatible format if needed.
- Save the file.
- This can help if the current file format is part of the problem.
- Turn on or verify AutoRecover
- In Word, select Word > Preferences.
- Under Output and Sharing, select Save.
- Make sure Save AutoRecover info is enabled and set the save interval.
- This will not fix the current save failure directly, but it helps reduce data loss if the issue happens again.
- If the file is stored in OneDrive, check available cloud storage
- If OneDrive storage is full, Word may open files read-only or fail to save changes until storage is available again.
- Check OneDrive free space from the OneDrive icon and Manage storage, or sign in to OneDrive and review used space.
- If the document still will not save, create a new copy
- Open a new blank Word document.
- Copy the content from the affected document and paste it into the new document.
- Save the new document with a new name.
- If the issue affects only one document, the file may be damaged
- Try opening it through File > Open and use Recover Text from the Open dropdown.
- Then save it again as Word Document (.docx).
- Note: formatting may change when recovering text.
If the problem started suddenly, the most directly supported fix is installing the latest Office updates. Microsoft also notes that save/autosave errors on Mac can happen when something interrupts Word’s temporary-file save process.
