Have some issues with my laptop... 0xc0000221 and 0xc0000225.
Masiosare 0 Reputation points
2026-09-20T05:32:08.2533333+00:00
After I finished using it, I tried to update and restart. Whole stuff glitched and the Recovery blue screen appeared, nothing happens when I press Enter, winRE not working, F8 not working, Safe Mode not working, only the firmware program and that is pretty much it. When I first boot it up it is the 0xc0000221, when I try and press F1 for recovery environment, it is now 0xc000025. Tried to repair my PC with a USB and it did not work. Reinstalling Windows 11 would be my last resort, but I am really considering it now. After several attempts, 0xc0000001 popped up, disappeared after another restart. What is my best solution and - if no fixing is possible - What is the best outcome?
Windows for home | Other | Performance and system failures
    2026-09-20T05:32:23.5433333+00:00
    Since WinRE from the internal drive is not working, F8 and Safe Mode are not working, and a repair attempt from USB already failed, the best remaining path is:
    1. Try a full power cycle and restart once more. In some cases, repeated boot failures are resolved by a restart.
    2. Boot from Windows installation or recovery USB again and use it to reach recovery tools from external media instead of the broken local recovery environment.
      • Start the PC from the USB.
      • Select Repair this computer.
      • Open Troubleshoot.
    3. From recovery, try these options in this order:
      • Uninstall updates: Troubleshoot > Advanced options > Uninstall updates. This is the best option if the problem started right after an update. Files and apps are not affected.
      • Reset this PC: Troubleshoot > Reset this PC. Choose to keep personal files if that option is available. This reinstalls Windows.
    4. If recovery options still fail, reinstall Windows from installation media. This is the most likely best outcome when startup repair and recovery tools do not work.
      • Warning: reinstalling Windows from installation media removes everything from the device.
      • For best compatibility, use recovery media from the PC manufacturer if available, because it can include hardware-specific drivers and factory apps.
    5. If important files are still on the laptop, prioritize file recovery before a clean reinstall if possible.
    Given the symptoms—multiple startup error codes, broken local WinRE, and failed USB repair—the practical best solution is usually booting from external installation media and either using its recovery tools or proceeding with a reinstall. If external recovery tools also fail, the best outcome is a clean reinstall of Windows 11, ideally using OEM recovery media when available.
    If BitLocker is enabled, the BitLocker recovery key is required to access most recovery options in WinRE.
  2. Masiosare 0 Reputation points
    2026-09-20T05:33:31.9933333+00:00
    Forgot to mention, I can't even use the cmd screen. Nothing at all.
  3. DaveM121 936.1K Reputation points Independent Advisor
    2026-09-20T06:07:05.6933333+00:00
    If those other methods are not working to access the Recovery Environment, are you able to force your laptop into the Recovery Environment using these steps.
    Start your laptop, just as Windows attempts to load (spinning dots), press and hold Power Button for 5 - 10 seconds to perform a Hard Shut Down
    Do this twice
    On the third start Windows will boot into the Recovery Environment and from there you can access System Repair, Safe Mode, Command Prompt... etc.
