Startups: Companies that are in their initial stages of business and typically developing a business model and seeking financing.
For an existing failed Microsoft for Startups business verification in the new Azure Portal experience, the supported path is Microsoft for Startups Program Support, not the general Azure technical support categories.
Use one of these supported routes:
- In Azure Portal, go to the startup homepage.
- Open the Overview tab.
- In Your Microsoft Team, select Get program support.
If that option is missing in the new experience, submit a support request from Azure Portal for Azure technical issues only by using:
- Sign in to Azure Portal.
- Select the ? icon in the top-right.
- Select Help + support.
- Select Create a support request and attach screenshots or relevant documents.
For Microsoft for Startups program-specific support, the documented note says to use https://aka.ms/startuphelp-mfs-portal.
Program Support is the team that handles:
- business or domain verification
- application review, approval status, or reapplication questions
- Azure credit activation issues
- benefit redemption issues
- entitlement and ownership corrections
- portal access problems
Program Support does not directly handle Azure service outages, production debugging, architecture design, or performance tuning.
For verification-related cases, the documented guidance is to provide current supporting documents and ensure the business name and address match the startup profile exactly. If startup information was changed, that can trigger a new verification process.
