Microsoft 365 features that help users manage their subscriptions, account settings, and billing information.
A direct reset cannot be performed here.
Use one of these supported recovery paths:
- If another Global Administrator or Authentication Administrator exists
- That admin signs in to the Microsoft Entra admin center.
- Go to Entra ID > Users.
- Select the affected admin account.
- Open Authentication methods.
- Choose Require re-register MFA.
- This removes registered MFA methods such as phone numbers, Microsoft Authenticator apps, and software OATH tokens, and forces setup of a new MFA method at next sign-in.
- If no other admin can do this
- Submit a Microsoft 365 support request for sign-in recovery.
- If standard sign-in is blocked by MFA, use the unauthenticated support path mentioned in the support guidance: choose “I can’t sign in” so support can verify identity through alternate methods and initiate a secure MFA reset.
- If some security info is still available
- Sign in to the Advanced security options page.
- Add a new way to sign in or verify.
- Confirm it with the code sent to the new method.
- Remove the old method that is no longer accessible.
- Do not change all security info at once, because the account may be restricted for 30 days.
- If all security info is lost but the password is known
- Start sign-in.
- At Verify your identity, select I don't have any of these.
- Follow the prompts to replace security info.
- After replacement, there is a 30-day wait before sign-in is allowed.
- After access is restored
- Re-register Microsoft Authenticator or another allowed verification method.
- Add at least one backup verification method if organizational policy allows it.
- Manage user authentication methods for Microsoft Entra multifactor authentication
- Common problems with two-step verification for a work or school account
- Urgent Assistance Required – Unable to Access Microsoft Admin Portal Due to Lost Authenticator - Microsoft Q&A
- Set up multifactor authentication for your Microsoft 365 account
