Why outlook force me to activate to 365, and not allow me to login Email???
Hongxing 45 Reputation points
2026-09-19T04:49:29.6733333+00:00
Hello Microsoft,
You should fired your outlook product managers, the outlook app logout me, and keep asking me to activate Microsoft 365.
It's <profanity removed> annoying me that NOT allow me to login as usual, but force me to accept something that I don't want.
The steps are:
  1. Open outlook app
  2. [Accounts] window popup
  3. My account not there(i guess forced logout), I click [Add Email Account]
  4. New popup says "Hmm, it looks like Outlook is offline"
  5. I click [Go online]
  6. A prompt ask me to activate Microsoft 365, but cannot
  7. Stuck and keep looping here
Again, The product manager who make this stupid idea should be fired.
Hornblower409 15,950 Reputation points
2026-09-21T00:17:20.5533333+00:00
@Hongxing said
it looks like Outlook is offline ... A prompt ask me to activate Microsoft 365
You tagged your Question as | Classic Outlook for Windows | , but it sounds like you have hit the known bugs in Outlook for Mac 16.113
  • Prompted for a Microsoft 365 subscription
  • Can not switch out of Legacy mode
  • Outlook stuck offline
Fixed in the latest release - Version 16.113.1 (26091740) from the App Store.
See the Answer by "Hornblower409 Sep 17, 2026" in
https://learn.microsoft.com/en-us/answers/questions/6006979/free-outlook-not-365
If this not the case, can you please provide a screen shot of the first error message you receive and see this Microsoft Support article and reply with what platform (Windows, Mac, Android, iOS) and version of Outlook you are using (e.g. Classic, New).https://support.microsoft.com/en-us/office/what-version-of-outlook-do-i-have-b3a9568c-edb5-42b9-9825-d48d82b2257c
Thomas4-N 22,295 Reputation points Microsoft External Staff Moderator
2026-09-20T10:43:47.5866667+00:00
Hello Hongxing,
I’m sorry you’ve been stuck in this loop. I understand why repeatedly being taken to an activation prompt instead would be frustrating.
If you believe Outlook should not be behaving this way and mainly want Microsoft to be aware of it, you can report the experience through Feedback Hub. Microsoft Q&A is just a community place; we're all normal users just like you here.
If you would rather troubleshoot it here, I’d be happy to help:
  • Do Word or Excel also ask you to activate Microsoft 365?
  • In Outlook, under File > Office Account, what does Product Information show for the activation status?
Let me know if you need help. Thanks for your understanding.
1 additional answer
    2026-09-19T04:49:44.8666667+00:00
    This usually happens when Outlook is treating the sign-in as a Microsoft 365 app activation/account state problem instead of just an email sign-in.
    For a home scenario, the supported checks from the available guidance are:
    1. Sign in with the correct account for Microsoft 365
      • If Microsoft 365 was purchased with a different personal email address, sign in with that account instead.
      • If the Microsoft 365 product or subscription is not associated with the account being used, Outlook can keep prompting for activation.
      • The account used for Microsoft 365 apps is the account tied to the license.
    2. Check whether multiple Office installations are causing activation failure
      • In Windows 11/10: open Control Panel > Programs > Programs and Features.
      • Search for office.
      • If more than one version of Microsoft 365 or Office is installed, uninstall the version not being used.
      • Restart the PC.
      • Open an Office app again and sign in.
    3. Create a new Outlook profile
      • Exit Outlook.
      • Open Control Panel > Mail.
      • Select Show Profiles > Add.
      • Enter a new profile name and complete the Add Account wizard.
      • In Mail, set Always use this profile to the new profile.
      • This can fix account/profile state issues when Outlook is stuck in a sign-in loop.
    4. If Outlook keeps prompting for credentials in older affected Outlook versions
      • Exit Outlook.
      • Open Control Panel > Mail > Show Profiles > select the profile > Properties > E-mail Accounts.
      • Select the email account > Change > More Settings.
      • On the Security tab, set Logon network security to Anonymous Authentication.
      • Finish the wizard and reopen Outlook.
      • This applies to older affected Outlook versions. Newer Outlook 2016 and some newer Outlook 2013 builds are noted as not affected by this specific setting issue.
    5. If the mailbox was migrated to Microsoft 365 and Outlook still cannot connect
      • Create a new Outlook profile first.
      • Another documented option is setting the registry value ExcludeLastKnownGoodUrl=1 under the Outlook Autodiscover key.
      • Warning: registry changes are risky; incorrect edits can affect Outlook or Windows behavior.
    A key account behavior to keep in mind: Microsoft 365 apps do not support being signed in with multiple user accounts from the same Microsoft 365 organization or tenant at the same time. One account may need to be signed out before another can be used.
