A family of Microsoft word processing software products for creating web, email, and print documents.
Try these steps in order:
- Update Office
- Open any Office app if possible.
- Go to File > Account > Update Options > Update Now.
- If Update Now is not shown, select Enable Updates first.
- Let all updates install, then try Word again.
- Start Word in Safe Mode
- Press Windows + R.
- Type winword /safe and press Enter.
- If Word opens in Safe Mode, the problem is often an add-in.
- Disable add-ins
- In Word Safe Mode, go to File > Options > Add-Ins.
- In Manage, select Word Add-ins or COM Add-ins, then select Go.
- Clear one add-in, select OK, then restart Word normally.
- Repeat until the faulty add-in is found.
- Older add-ins such as ABBYY FineReader and Dragon Naturally Speaking are known to cause problems.
- Repair Office
- If Safe Mode does not help, run an Office repair.
- A Quick Repair can be tried first.
- If that does not fix it, use Online Repair.
- Note: Online Repair is more thorough and may effectively reinstall Office.
- Check Windows and device drivers
- Go to Settings > Windows Update and install available updates.
- If the issue continues, update drivers for the video card, printer, mouse, and keyboard.
- Use Word troubleshooting startup mode
- Type winword /a and press Enter.
- This starts Word without add-ins and global templates and helps identify whether startup components are causing the issue.
- Reset the Word Data registry key
- This can fix damaged Word settings.
- Warning: editing the registry can cause serious problems if done incorrectly. Back up the registry first.
- Close all Office apps.
- Open regedit.
- Go to:
HKEY_CURRENT_USER\Software\Microsoft\Office\16.0\Word\Data - Right-click Data > Export and save the backup.
- Right-click Data > Delete.
- Start Word again.
- If this does not help, restore the saved
.regfile.
- Reinstall Office if needed
- If Word still will not open after updates, Safe Mode, add-in checks, and repair, uninstall and reinstall Office.
